ANY LINKS!!!!! READ guys! Jeesus Tony =P. I just added that part to my original post.
Frogeye-
What's the point of a poll if you're going to confuse the issue by adding a brand new product to the mix. The AP links should not be included at all. Just stick with the OEM links and keep it simple.
TLCA#16768
33' BFG MUD's, Icon Front Coil Overs, OME Rear Shocks and Coils. ARB Bumper, Warn 9500XD winch, MAF Sliders & Skid Plates, Gobi Ranger Rack w/ PIAA Lights ft, rr, sd, w/Gobi Hi Lift, axe and shovel Mounts, dust lights. Dirty Parts Dual Battery System, Cobra 75 WX ST CB, Extreme Hi Lift Jack, Power Tank 10 lbs. CO2 System, All Pro HD LCA's, Custom Rear Drawers. Custom electrical.
MY point is.... IT doesn't matter what links! AND I bet it doesn't matter what brand of coilovers either. Links are bending and breaking, stock links and aftermarkets. Stop breaking my balls already.
I have a feeling those breaking/bending are the ones that do high speed desert bombs. Maybe rock crawling won't make as much of a difference. I'm just guessing. When you respond to the poll can you also describe your driving style? I know Uphill doesn't do the high speed runs and he didn't bend or break his stock links, but he changed them as a precaution. I'm not sure how FJcruiser123 drives or how Dustpark drives either. Figuring out what kind of activity stresses the links more will help in the redesigns.
Sandoo Blue FJ
i had one with the all pro front suspension and 2 with the old man emu heavy.
Typical off road nothing hard core. I more sway bar link due to stupidy that does not count because i killed the axle on the passenger side also
All links on the passenger side, last time the link bolt fell out after the dealer put it in and they would not cover it and told me the sway bar was bent.
So F@CK the sway bar i am and have been running without it for about 4 months with pro comp limit straps and heavy front suspension no problems.
Who needs the hassle when you can just go to limit straps.
Hell the dealer will not even fix the diff leak because i welded a skid to it F@CK DEALERS ALL OF THEM.
Blackcherry--what length did you set your limit straps to, where did you get them, and what did it take to install them? I'm considering going the same route--I wheeled this weekend with no swaybar and it was awesome, just need to limit droop to prevent damage.
My Links bent on Holcomb Creek, and Coyote Canyon. It is from a shifty sway bar in my opinion. That makes the link ****ed offcentered, it is not so forgiving in the position causing it to bend.
I bent the passenger link on the clark summit dirt road. This trail is on the south side of Big Bear and is fairly easy. I wasn't aired down and I was somewhat pushing it.
Regards, SSC
2007 Blue Mamba, All-Pro Fox suspension all the way around, All-Pro sliders, skids, front and rear bumpers. Warn 9.5xp winch. 285-70-17 BFG-KM-2's. and a Puddy cat
