View Poll Results: Pick an option that best describes your FJ's config
Walker Evans : Bent Both Driver and Passenger 1 9.09%
Walker Evans : Bent Front Driver Link 0 0%
Walker Evans : Bent Front Passenger Link 1 9.09%
Da HOs : Bent Both Driver and Passenger 0 0%
Da HOs : Bent Front Driver Link 0 0%
Da HOs : Bent Front Passenger Link 1 9.09%
Old Man Emu : Bent Both Driver and Passenger 1 9.09%
Old Man Emu : Bent Front Driver Link 0 0%
Old Man Emu : Bent Front Passenger Link 1 9.09%
Stock : Bent Both Driver and Passenger 0 0%
Stock : Bent Front Driver Link 1 9.09%
Stock : Bent Front Passenger Link 2 18.18%
Misc/other Coilovers : Bent Both Driver and Passenger 0 0%
Misc/other Coilovers : Bent Front Driver Link 1 9.09%
Misc/other Coilovers : Bent Front Passenger Link 2 18.18%
Voters: 11. You may not vote on this poll
Old 04-04-2008, 06:00 PM   #41 (permalink)
Singha's Avatar
Member Number: 12233
Re: The Bent/Broken Link Poll
WOW, Those things are scary looking. Having second thoughts now on going AP.
and the hassle of maint.
Might have to go stock OEM.
TLCA#18914
GCLC#2083
NYC
Ti 6sp. CQ GY UP C7 37 2Q.
ADDED 6D(x2),EL,V5,WL(x2).
SE Speced PLUS/TRD CAI,Q/Shift,Raditor Cap,JDM TRD gas cap cover.
MODS
AllPro Sliders,E-Locker+Diff skid,R-LCA,Bandi,Digger R-UCA,OME 883+TP14(w/TRDs),Rear OME 895E(w/TRDs),Rasta Skid plates,TC A-Arm Skids,Lucrum mount WO/winch.
Hella horns,Husky mats,SGII,Osram SilverStar,OEM Brush Guard w/Hella 500FF,LightBar w/ 4 Hella FF50,
Dave Crums NEW Rear Trailing Arm MOUNT. Amsoil Gears Oil.
Singha is offline
Old 04-04-2008, 06:07 PM   #42 (permalink)
Singha's Avatar
Are these the right OEM Part#s for replacements?
R 48820-60050
L 48810-60040
TLCA#18914
GCLC#2083
NYC
MODS
Singha is offline
Old 04-04-2008, 08:36 PM   #43 (permalink)
Cred's Avatar
Member Number: 3968
Oh man I bet they look like poop. I can't see them here at work. I'll check it later tonight. Cred btw, what are you using to lube the links? I've been hitting them with WD40.
I have been using PB Blaster lately. Prior to that I used Corrosion X but I was not that good at getting the links evidently.
TLCA # 18365
Cred is offline
Old 04-05-2008, 03:30 PM   #44 (permalink)
ruebarb's Avatar
Member Number: 1493
Cred previously said: View Post
Paint your links with Por-15, it stops the oxidation and won't chip
ruebarb is offline
Old 04-06-2008, 09:30 AM   #45 (permalink)
Singha's Avatar
My sway bar the alum rings where ****ed eye on both side by about 2.3-4mm.
So I took the sway bar off tap the rings over and installed two lock collars I got from Fastenals($7 each). Let see if this will fix my problem.
TLCA#18914
GCLC#2083
NYC
MODS
Singha is offline
Old 04-06-2008, 11:52 AM   #46 (permalink)
frogeye's Avatar
Member Number: 6849
Singha previously said: View Post
I'm not sure about those part numbers but you will be fine with the stock links as long as you clamp the sway bar down to prevent it from shifting. Happy trails to you sir.
frogeye is offline
Old 05-01-2008, 12:52 PM   #47 (permalink)
Cred's Avatar
Member Number: 3968
Is the glass half full or half empty?
Had to post today because you won't believe this. Went to the dealership to order some parts and talk with the service guys. As I turned out of the dealership I heard a clunk sound. I turned back into the dealership and found I had a broken link with a freshly torn cv boot! My rusty as hell AP link (drivers side) snapped in half.
Here is a pic from last month when I realized they were rust magnets.
I didn't have my camera with me to take a pic of the broken link but I will take a pic after the dealership replaces it.
I should have removed them like I had planned but it didn't happen. So I got back in and drove into the service bay and told them what happened and what I needed. Ordered some more parts and got a ride back to work from one of my coworkers.
So, I was on my lunch break and it broke right in front of the dealership. Parts will take 2 days
No towing
Out of some cash
My wife is not pissed.
My glass still looks half full to me!
TLCA # 18365
Cred is offline
