Old 10-23-2007, 08:27 AM   #1
Wheeler's Avatar
Member Number: 9216
Limit straps--question
Whats up all, tried to find this by searching but came up with nothing.
I wheeled this weekend sans swaybar and it was incredible...but I know that with increased droop I increase my likelyhood to sustain CV damage.
I'd like to install limiting straps, but am unsure of installation procedure, and most importantly which strap length/manufacturer to go with.
I'd appreciate any insight you could provide! Thanks!
Wheeler is offline
Old 10-23-2007, 09:25 AM   #2
Mtbcoach's Avatar
Member Number: 2433
Re: Limit straps--question
Most would advise to measure the droop with the swaybar on then replicate that limit with a strap. I'm in the process of doing the same and when I find some suitable solutions, I'll be sure to post up what I have come up with.
Sorry for the lack of details, I'm still in the research phase and will benefit from your question also...
'07 GSJ15, well enhanced
'97 FZJ80 OME J
'71 FJ40 stock
Olde North State Cruisers TLCA delegate
Train Hard, Rest Harder
TLCA 17784 - FCC KJ4KGF
Mtbcoach is offline
Old 10-23-2007, 09:42 AM   #3
tibaal89's Avatar
Member Number: 8825
Send a message via AIM to tibaal89
Mtbcoach previously said: View Post
I'm in the same boat - planning to do this soon, but not able to offer anything scholarly at this point. I'll let you know how it goes though!
-Mike (KE7ULD)
check out my BLOG thing...
AZFJ.org - Arizona FJ Cruisers!
Something there is that doesn't love a wall, that wants it down...
tibaal89 is offline
Old 10-23-2007, 10:35 AM   #4
jeshua's Avatar
Member Number: 6888
Like mentioned in the post above measure your drop with the sway bar in as that is going to be your limit. It might even be easier if you kept the sway bar in while you installed your straps.
As for installing the strap(s) I will give you two diffrent ways
(picture courtesy of All Pro)
For the green line use the lower shock mount bolt as the lower attachment of the strap. Then drill a hole in the coil over bucket to use as a mounting point for the top of the strap.
For the red line the lower portion of the strap would be the same as the green line. For the upper part though you would weld this piece on to the frame
then this would go thru the welded on bracket
would look like this in the end
Going with the red line you will be able to fine tune your straps.
As for straps there are lots of good company's to go with call ORW or Kartek for all of this stuff and they will help you out. Also to let you know when getting straps you need to know that they stretch about 1" for every 12" this will very depending on the straps so you need to talk to your salesmen.
Mike Ambs
www.corva.org
- Thomas Paine
Aequitas - Veritas
jeshua is offline
Old 10-23-2007, 10:39 AM   #5
Bighead's Avatar
Member Number: 11775
A couple of limit strap manufacturers for you:
Mastercraft
-- I have these on my 4Runner.
Kartek
2001 4Runner Limited 4X4 -- 315/75R16 MT/Rs | MT Classic IIs | Dual ARBs/4.88s | (F) 5125/Tundra Coils (R) 5125/LC Coils | 4Crawler 1.5" BL | Aisin Manual Hubs | Slee Sliders | Sonoran Steel Rear Bumper | TJM T-15 w/ Warn M8000
Bighead is offline
Old 10-23-2007, 03:00 PM   #6
Wheeler's Avatar
Member Number: 9216
Excellent info, thanks all!
If anyone already has measurements please post them here! Thanks again!
Wheeler is offline
Old 10-25-2007, 10:23 PM   #7
puulboy's Avatar
Member Number: 8494
I would like to hear from anyone here who is running limit straps. Maybe pics of the mounting, which straps they use. what are the sizes etc. I can't believe no one has does this for a member mod post yet
thanks
Don
AZFJ founding member
www.wikidfj.com under construction
http://wikidfj.blogspot.com/
Member build page
http://www.fjcruiserforums.com/forum...other-gal.html
I would like to thank the following companies for working with me on Wikid
Total Vision Products
Allan Phillips Racing
Camping Labs
Baja Racks
Ricochet Skids
http://www.lubedealer.com/supra
Just for fun
http://www.discounttiredirect.com
puulboy is offline
Old 10-26-2007, 12:03 AM   #8
Canito is1's Avatar
Member Number: 3886
Send a message via AIM to Canito is1
Why not just create a bump stop... on second thought, the limiting strap may be easiest
Zane
2007 Titanium 4x4 AT
Convenience Package, Upgrade #2
Sway a Way RaceRunner's F&R, 275/70 MT/R's, ARB, Warn M8000, IPF 968's, original cut-hack, TRD sliders, Cobra 75WXST w/ Firestick, dbbd1's hi lift brackets & hi lift, K&N drop in
Canito is1 is offline
Old 10-26-2007, 12:08 AM   #9
Member Number: 6427
i'm also interested, theres a few folks on here who have them...lets hope they post some pictures...and measurements...would save me two trips to the mechanic
hakim100 is offline
Old 10-26-2007, 12:16 AM   #10
frogeye's Avatar
Member Number: 6849
Thumbs up Re: Limit straps--question
Great info guys. I like the Weld option. Sizzling bacon baby.
Chris
frogeye is offline
