I have the OME 895's and they are a bit stiff. I want to switch to donahoe but Im concerned that I will get some sag when adding the Demelllo rear bumper. So I'm considering just switching out the rear shocks to donahoe at first and then see if I get any sag with the demello bumper before switching to the donahoe coils as well
Good plan. It is always best to just do one change at a time when your trying to get your suspension figured out.
- Thomas Paine
Thong if you read this can I get the specs on your custom springs? I now you posted them some were but I don't remember were.
- Thomas Paine
Thanks T.
I will give you a call tonight and see what you think about my idea.
- Thomas Paine
I wonder what the toytec's are? I should have measured befoer I put them on.
2007 VooDoo Blue Toyota FJ Cruiser 4x4 Auto - Garmin GPS, Toytec 3" lift kit (OME 884 front springs with spacers, toytec custom rear springs with pro-comp 9000 shocks), a-trac switch installed, a-trac/rear locker hack, and rear locker hack in 2HI/4HI, Mobil 1 synthetic rear diff. fluid, pioneer premier TS-A932P 6x9's and power acoustiks PR-132C 3.5's in the dash and rear pillars with factory base stereo.
Great thread Josh! rep points buddy This is just in time of what Larry (uphill) and I were discussing a couple of days ago. I'm running the DR's and have no sag when I added the AP rear bumper. Now once I add the Man--Free fuel tanks under the FJ down the road, I will be maxing out the DR springs, this is what Jason also says. I will have added a lot more weight by then too. A sleeping platform with air tools, recovery tools, spare parts, water, fuel, etc. I'll move up to some heavy's at that point.
Thanks for the Rep.
Glad I could help. I now I am having a hard time figuring out what I will do when $$ shows up and figured I am not the only one. I think I will end up going custom in the end like T. did.
- Thomas Paine
YES the HOES will SAG! mine did with stock bumper
OEM Rails- Midland CB with bandi mount antenna- BFG 285/70/17- DR 3" lift with body mounts trimmed -Total Chaos UCA's - All Pro High Clearance Tail pipe -All Pro 3 Piece Front Bumper With Large Light Bar - Hella, HELLA, HeLLa - Pioneer in dash NAVI- MOBIL 1 !!!
I am switching to OME 896's from Donahoe's in the rear to support the MAF aux. fuel tank and Fab Fours rear bumper. The rear Hoes (springs) will go up for sale. They're good as new but as one would expect, I'm going to discount them. Let me know by PM if any of you have an interest and we'll figure out the price.
EDIT: That was quick - Hoe rear coils are now spoken for.
