Old 06-19-2008, 07:11 PM   #61 (permalink)
Member Number: 18296
Re: Rear Spring Comparison
Yes, you are just not jacking up the rear as high as the 895 and you don't have to therefore crank up the adjustable CO's much to level the truck. Somewhere I posted that you might be able to stay within front end alignment specs by using the 895E in the rear which corresponds to less lift in the front which is a good thing - many owners need aftermarket upper control arms to get an alignment.
2007 TOYOTA FJ Cruiser - Black Cherry Pearl with pinstripes
Done - K&N drop in, rear window mod, Hella FF's,
Demello Offroad hybrid sliders, Camburg coilovers - (700 lb./inch Eibach springs), OME 895E/N141 rear, CB/Bandi-mount, BFG MT 255/75 on 2nd set of alloys, Scuba Squad Mod all four breathers (AT5), front-to-rear mud flap swap
Fresh off UPS truck - DO skid plate
FJ's FJ is offline
Old 06-21-2008, 06:27 PM   #62 (permalink)
SoloSK71's Avatar
Member Number: 12298
Location: Somewhere in the woods of Northern Alberta, Canada
Although mentioned in a couple of earlier posts, you can order directly from Coil Spring Specialties -- individually calibrated coil springs for any suspension need. and you can 'dial in' the exact lift and increase in spring weight that you want. Very helpful guys and still near the same price as the ones mentioned above.
- Solo
2007 Toyota FJ Cruiser ... and some mods.
You are just jealous because the voices only talk to me!
When Solomon Kane went forth again no man knew his road.
treadlightly!
SoloSK71 is offline
Old 08-10-2008, 09:15 PM   #63 (permalink)
jess_342's Avatar
Member Number: 10521
nice thread. does anyone know of a coil that is stock height w/ a higher spring rate, i don't have the money to spend buying a full lift, but i need more support in the rear. my stock springs are leaning to the left almost 3/4" lower than the right with almost empty tank of fuel.
NOW: Black 07, AT, Convience Package, 4x4, locking RR, ATRAC "added", Demello Hybrid sliders, OME 883, Hankook Dynapro MT 285/70/17, baja EXP roofrack
LATER: full skids
WAY LATER: Winch mount, winch, more lights
jess_342 is offline
Old 08-10-2008, 09:23 PM   #64 (permalink)
jeshua's Avatar
Member Number: 6888
jess_342 previously said: View Post
The only thing I can recommend is to keep an eye out on the classifieds section for a set of used rear springs. People will up grade to stiffer OME some times and sell there old set of soft or med OME's. then just get a spacer lift in the front till you can spend the money on a good lift. Or call CSS and have some custom rear springs made to your specs. Good luck.
Mike Ambs
www.corva.org
- Thomas Paine
Aequitas - Veritas
jeshua is online now
Old 08-10-2008, 10:13 PM   #65 (permalink)
jess_342's Avatar
i already have OME 883's in the front, so i am not sure what spacer i could use. i actually have a daystar 1.25 top spacer in my garage, do think that would be OK, with the 883's and then OME mediums or so in the back?
LATER: full skids
jess_342 is offline
Old 08-10-2008, 11:33 PM   #66 (permalink)
jeshua's Avatar
Member Number: 6888
NO!!!! Do not put the spacer on with the OME 883's! That would over extend your cv's, steering and the rest of the suspension causing it all to wear out and or break.
So you are running OME 883's front and stock rear? If so you shouldn't have to worry if you put some OME 895's in the rear, it should match with the front nicely. If thats more lift then you want try the Downey springs there a little shorter and softer but have a longer free length. Just not to sure on how they stand up over time since I haven't read much about them.
Mike Ambs
www.corva.org
- Thomas Paine
Aequitas - Veritas
Old 08-11-2008, 08:38 PM   #67 (permalink)
jess_342's Avatar
i do have stock rear springs, i was thinking the 895's would give the rear too much lift and i would have a raked fj again. i haven't heard about downey springs. does anyone else have a similar set up with OME 883 and something besides stock springs in the rear?
LATER: full skids
jess_342 is offline
Old 08-12-2008, 12:50 PM   #68 (permalink)
projekt4's Avatar
Member Number: 16605
im running the downey rear coils, rear donahoe shocks, with donahoe c/o's up front. the downey coils don't lift the rear quite as much and have a great ride. the spring rate from downey works well for light to medium loads. i like em
BFG315/70/17KO's
Demello up frt
Demello skid
DR susp.
MagnaFlow
KC rally 800's
projekt4 is offline
Old 09-09-2008, 08:58 PM   #69 (permalink)
FJ #8's Avatar
Member Number: 121
i have the ome 895 in the rear and i am thinking of switching them out to the icons springs to go wiht the new icon shocks. I;m wondering if the actually lift height is the same with these?
FJ #8 is online now
Old 09-09-2008, 09:06 PM   #70 (permalink)
DominicG's Avatar
Member Number: 1647
FJ #8 previously said: View Post
Yes, They are both the same amount of lift.
But, when loaded down you will notice sag way earlier than with the 895's.
Then again, these will match up beautifully with your new shocks.
http://img.photobucket.com/albums/v257/humprnr/pink-1.png
Jeebus Is Coming
LOOK BUSY!!
DominicG is offline
