Old 12-27-2007, 04:48 PM   #1 (permalink)
MoabFJ's Avatar
Member Number: 5798
Which rear shocks with an OME lift?
I have approached several vendors with what I thought was my perfectly researched lift:
Front, OME885 medium front coils with N1405 shocks (w/Toytek leveling spacer).
Rear, OME895 medium rear springs with N71 shocks.
My understanding is that the standard rear N141's limited articulation, and the
answer was to use the N71's. Now I have been told the N71's are not recommended for the FJ.
I have always disliked spacer lifts, and do not want to mix vendors equiptment (ie, Toytek rear springs).
Is anyone running the N71's with the OME springs? are you happy with it?
Thanks!
A good day, is a day that ends with a St. Bernardus ABT 12
MoabFJ is offline
Old 12-27-2007, 04:51 PM   #2 (permalink)
FJ #8's Avatar
Member Number: 121
Re: Which rear shocks with an OME lift?
MoabFJ previously said: View Post
Thanks!
i have the OME895/n71 setup, I have been happy but am gonna switch out to the donahoe setup
FJ #8 is offline
Old 12-27-2007, 05:02 PM   #3 (permalink)
estysalinas's Avatar
Member Number: 13250
This probably isn't much help but i run the N71s with a Toytec spring.
2008 Titanium FJ with OF Package
*Bud Built Skid Plates
*Trail Gear Rock Rails
*Toytec 3" Custom lift
*Scuba Rear Diff breather mod
*Uniden PC78XL w/firestick 3ft
*285/75/16 Hankook Dynapro MTs
*ARB Roof Rack
*Soon: ARB Front Bumper
estysalinas is offline
Old 12-27-2007, 05:17 PM   #4 (permalink)
MoabFJ's Avatar
Member Number: 5798
Toytek wants to use the N71 shocks with their rear springs.
I just like the idea of a well thought out suspension SYSTEM, with a single manufacturer for all of the components. I have rarely liked the results of a "mixed bag of parts" approach to wheeling suspensions.
If someone has this setup, for better or worse I would like to hear about it.
MoabFJ is offline
Old 12-27-2007, 05:18 PM   #5 (permalink)
MoabFJ's Avatar
Member Number: 5798
FJ #8 previously said: View Post
Just out of curiosity, why are you switching? anything you particulary like or dislike?
MoabFJ is offline
Old 12-27-2007, 11:20 PM   #6 (permalink)
That was my orginal idea as well...but group buy time came and i couldn't resist :-). To be honest i like the setup it rides pretty nicely on the street and handles offroad very well.
*ARB Roof Rack
Old 12-29-2007, 01:09 AM   #7 (permalink)
tisilverFJ's Avatar
Member Number: 1394
Thanks!
The OME 141's are not much longer than stock which limit articulation. When changing out to longer than stock coils (895's are about 2" longer) you need to add longer shocks. Since my FJ is my only ride I switched from the 895's to Toytecs coils. I did not like the stiff ride of the 895's. It felt the same as when I added a HD add-a-leaf to my Tacoma. Gave it lift but lost the nice smooth ride. Toytecs coils are also longer than the 895's which add even more articulation.
Stock vs. OME 141
Stock with OME 895 coils
Stock vs. OME N71
OME N71 with OME 895
Articulation
TLCA#16292
Toytec custom coil lift,SS brake lines. PM me for Discountshttp://www.toyteclifts.com/fjcruiser...ruiserliftkits
All Phase Offroad diff skid,engine skid,Hi-Lift mount,axe/shovel mount,HD LCA frame mounts.
Spidertrax spacers.
All-Pro HD LCA's,Bandi mount.
FabFours front bumper w/PIAA lights
Stock Toyota steel wheels with 35" MTZ's.Gas/water cans mounted to stock rack. Midland hand-held CB. Thule fairing. OEM rock rails. A-Trac/Locker hack.
tisilverFJ is online now
Old 12-30-2007, 07:43 AM   #8 (permalink)
FJ #8's Avatar
Member Number: 121
Only reason I am switching is to have all the same suspension setup. I have the donahoe UCAs/coilovers so I wanna switch out the rear. I only got the OME in rear b/c donahoe didnt have a rear setup when I changed out the suspension.
FJ #8 is offline
Old 12-30-2007, 11:19 AM   #9 (permalink)
Prof T's Avatar
Member Number: 6710
Nice work.
Prof T is offline
