Old 12-30-2007, 07:33 AM   #1 (permalink)
FJ HOG's Avatar
Member Number: 9969
ome 886 with stock shocks
I have a trd se with the warn front bumper and 8000 winch, Can I just add the 886 coils and keep the bilsten shocks to level it or do I need to swap out the shocks also???
mods -- Warn bumper, Warn m8000 winch, running lights and fog lights.
FJ HOG is offline
Old 12-30-2007, 10:09 PM   #2 (permalink)
Member Number: 4191
Re: ome 886 with stock shocks
It might be good to swap out the stock shocks with some OME struts. I have a tacoma with 885's in the front, and I originally ran it with the stock Bilsteins, and it was a little rough. I recently installed OME n140S and am very happy with them. Rides very nice
07 Tacoma DC TRD. OME 885's, Alcan AAL's, OME n140S,Bilstein 5100 Rear Shocks TRD Front Skid plate, TRD Ivan Stewart's, BFG AT KO 285/75/16, OME Shims, OME Carrier Bearing drop.
Brandon H is offline
Old 01-02-2008, 05:25 AM   #3 (permalink)
FJ HOG's Avatar
Member Number: 9969
Thanks Brandon.
FJ HOG is offline
Old 01-02-2008, 06:25 AM   #4 (permalink)
FJ FunJunkie's Avatar
Member Number: 7470
Actually the 886 coils reqire the struts to be swapped out, the lighter coils can be used with the oem but the 886 are just too stiff and tall for the stock ones.
Ligten up, it's the internet!
Quote from: BigDouggieDoug
You Should Help Chris Walk
FJ FunJunkie is offline
Old 01-04-2008, 01:54 PM   #5 (permalink)
FJ HOG's Avatar
Member Number: 9969
FJ FunJunkie previously said: View Post
Thanks for the info. decsions, decisons. New struts, but can I keep the stock bilsten shocks????
FJ HOG is offline
Old 01-04-2008, 02:17 PM   #6 (permalink)
fjessence's Avatar
Member Number: 11287
Send a message via AIM to fjessence
the stiff coils might cause your shocks to blow out, mine did after only 1500 miles with them on
Voodoo Blue 4x4 AT QC UR C7 V5 Z2
Mickey Thompson 265/70/17 Baja MTZ's, Moto Metal MO957 17" -12mm offset, All Pro Sliders, Blue RockBlockers, Painted front bezel, PIAA Extreme white bulbs, billet short stubby 9 inch antenna, AVS In Channel Vent Visors, OME 884 front coils with 5mm Toytec spacer, Raptor Muffler with dump before axle, Toytec custom stock ride rear coils, OME front and rear nitro shocks
and the mods keep coming....and my wallet keeps crying..
-Sang
fjessence is offline
Old 01-04-2008, 03:12 PM   #7 (permalink)
Mtbcoach's Avatar
Member Number: 2433
I can't imagine that the stock shocks can be extended an additional 3+" with the OME 886's. I have a Demello bumper, winch and BudBuilt skids and I still have 3" of lift.
Do an experiment...take the time to remove a strut and see if it can be extended 3". Even if you can, still don't think that it will be an effective piece of suspension being put at the extremes of its range but it might give you an idea if it will "work".
Just put the TRD shocks in storage and save up for the OME complete kit, its well worth it...
Demello sliders
Demello rear bumper
Inchworm Lefty
ARB front air locker
Nitro 4.88 gears
Bud Built skids front to back
Super Swamper SSR 35 X 10.5
Safari Snorkel
Train Hard, Rest Harder
TLCA # 17784
Mtbcoach is online now
Old 01-05-2008, 08:15 AM   #8 (permalink)
FJ HOG's Avatar
Member Number: 9969
Mtbcoach previously said: View Post
I can afford the new struts and coils for the front end, (dat way momma don't get mad!) I still have the stock rear bumper. Could I just lift the front?
FJ HOG is offline
Old 01-05-2008, 09:08 AM   #9 (permalink)
Mtbcoach's Avatar
Member Number: 2433
FJ HOG previously said: View Post
Sure, you could but I would imagine that you would be very front high with that set up. I can only imagine an ill-handling vehicle, decreasing front visibility.
You best bet might be what others have done and go with the OME 883 springs with the stock struts. Many have been happy with this result in that it gets "close" to leveling out the rig.
Do a quick search with the parameters "ome 883 springs" and you will be able to read and see what other's rigs have come out with this set up...
Demello sliders
Demello rear bumper
Inchworm Lefty
Nitro 4.88 gears
Safari Snorkel
TLCA # 17784
Old 01-05-2008, 10:32 AM   #10 (permalink)
Go4aRyd's Avatar
Member Number: 2937
Just had a similar discussion with Doug at Toytec (forum sponsor), and would recommend you consider that as well. He was extremely helpful and really understands what works together and what doesn't really fit well, particularly with respect to the OME coils and various shock options.
BTW - many say the heavies are too stiff - even with the winch + bumper combo...see http://www.fjcruiserforums.com/forum...ion-trade.html
-cheers
Go4aRyd - Voodoo Blue, AT, TRD wheels, BFG A/T KO, WHITE bezel, Demello sliders, Gobi Stealth rack&ladder, PIAA lights, Lowrance Baja 480C, dual battery.
Go4aRyd is offline
