Old 01-03-2008, 05:13 PM   #1 (permalink)
Wuddup's Avatar
Member Number: 12249
Radflo Shocks for RC 6inch.
The Radflo Shocks come out for the Rough Country 6inch lift tommorow. Tommorow I should have complete info on them, unless Glenn aka Radflo Shocks post it. Either way im game once the funds come in.
17 and Fj Cruising
Mods:TRD CAI, JBA Exhaust, Viper Alarm,RC 6inch lift, Super Swamper SSRS, 15% tint front two windows, 5% rest, pro comp 6001 series rims, Fab Fours Front Bumper, Warn 9.5 Ti Whinch
Future: Headers, Y Pipe, Paint Job
http://www.fjcruiserforums.com/forum...ers-unite.html Hottest Dogs on this Site
http://www.fjcruiserforums.com/forum...tml#post624690My FJ 6inch lift from RC.Updated 1-6-08
Wuddup is offline
Old 01-04-2008, 09:20 AM   #2 (permalink)
Member Number: 15899
Re: Radflo Shocks for RC 6inch.
Wuddup previously said: View Post
This is correct, we now have coil overs available for the RC 6" lift. Please contact me for details.
Glenn
Radflo Suspension Technology
714 965-7828
Radflo Shocks is offline
Old 01-04-2008, 10:08 AM   #3 (permalink)
Sean K.'s Avatar
Member Number: 9441
I highly recommend Glenn at Radflo. I got some custom sliders for my Fox coilovers from him a while back. Excellent, fast service. Great guy to do business with!
Sean
Do you need a ladder so you can get the **** over it?
Sean K. is offline
Old 01-04-2008, 11:46 AM   #4 (permalink)
The specs of the shocks are as follows:
Radflo 2.0 coil over housing
7/8 Nitrosteel shaft (excellent corrosion resistance)
Billet top mount with mounting hardware.
Teflon lined spherical bearings
650 lbs/in spring (as per RC)
Please contact me directly if you have any specific questions or for pricing.
Glenn
714 965-7828
Old 01-05-2008, 11:41 AM   #5 (permalink)
seal13il's Avatar
Member Number: 14404
Send a message via MSN to seal13il Send a message via Skype™ to seal13il
so that means I buy the 6" rear and use these ones up front and than i have a good quality 6' lift?
seal13il is offline
Old 01-05-2008, 03:16 PM   #6 (permalink)
Kyle Dreaden's Avatar
Member Number: 8333
seal13il previously said: View Post
Negative. You're correct on the rear, that all you need is a new set of shocks, springs, and trackbar. It's easy to do the rear because it's a solid axle. The front is a different animal all together, being IFS.
If you were to put a set of coilovers up front long enough to give you 6" of lift, your CVs wouldn't last a minute as the angle would be way too severe. This is why 6" lift kits of the Rough Country/FabTech/ProComp come with extended knuckles, and the necessary hardware to drop your front diff a few inches, which in turn gives you CV angles nearly identical to that of stock (varying of course with the different kits).
The Rough Country base model 6" lift doesn't replace the front coilovers, just adds a strut extension spacer on top of the OEM coilovers. As far as I know, these radflo coilovers are meant to be put in place of the stock coilovers AND strut extension. However, I may be wrong and the extension spacer may still be required to get the full lift.
Anyone care to clarify that?
But bottom line, no, you can't get a 6" lift by doing just coilovers in front. You MUST drop the diff and you MUST install new knuckles.
THE VEHICLE: 2007 Titanium Metallic FJ Cruiser - AT 4x4 aka BRUISER
SUSPENSION: OME/ToyTec 3" - N140S Front Shocks, 885 Medium Front Coils, N71E Rear Shocks, ToyTec Custom Rear Coils
TIRES: BFG M/T KM2285/70/17 on Stock Alloys
EQUIPMENT: (4) PIAA Lights - Roof Racked, OEM Sliders
Kyle Dreaden is offline
Old 01-05-2008, 10:30 PM   #7 (permalink)
seal13il's Avatar
Kyle Dreaden previously said: View Post
tnx, i agree!.....any experts here to help us out?
seal13il is offline
Old 01-07-2008, 10:05 PM   #8 (permalink)
Wuddup's Avatar
My bumper weighed the FJ down a tad. I need new shocks in my top 3 most needed mods.
17 and Fj Cruising
Wuddup is offline
Old 01-08-2008, 08:57 AM   #9 (permalink)
These shocks are designed to replace the stock strut and the spacer.
On any coil over lift, you will only get a maximum of 3" of lift as you will run into problems with the cv joints binding and the boots tearing.
Glenn
714 965-7828
Old 01-08-2008, 07:33 PM   #10 (permalink)
Wuddup's Avatar
Radflo Shocks previously said: View Post
Glenn
How is it replacing the spacer? It would have to be a larger coilover seeing as the spacer is 5inches.
17 and Fj Cruising
Wuddup is offline
