Old 01-20-2008, 03:58 PM   #1 (permalink)
FJ #8's Avatar
Member Number: 121
ome suspension shifting
I have had my rear OME suspension on for around a year and all has been good. This weekend I noticed a clunking sound from the rear. When I checked it out I saw that the coil was shifted!! Has anyone had this happen?? I should be ok to driv eon it to and from work till this weekend,right? I havent done anything crazy to make it shift,just normal eveyrday driving.
here's a pic...........
[IMG][/IMG]
[IMG][/IMG]
FJ #8 is offline
Old 01-20-2008, 04:05 PM   #2 (permalink)
rlind31636's Avatar
Member Number: 15757
Send a message via AIM to rlind31636
Re: ome suspension shifting
That's weird. I have the OME front and rear lift as well. Wonder what happened? I'll go look at mine right now.
FJ Cruiser-ARB bull bar, Warn M8000, OME 2.5" susp w/springs, RR Lock Diff, sliders, BFG Mud Terrains T/A, TRD Exhaust, KC Slim Highlights, IPF Fogs, Hi-Lift Extreme w/roof rack mount
rlind31636 is offline
Old 01-20-2008, 04:20 PM   #3 (permalink)
TrAiLbUs1's Avatar
Member Number: 12292
Did ya catch air maybe?? I cant believe that shifted...hmm
Romp Master General Tucson Unified Romping District (TURD)
HEG LUMPER #666 full back!!
TucsonTrail Blazer
Chiva/Gap/cave canyon/rice peak/Chimney Rock
Northern AZ
Broken Arrow/Cinder Hills (Suicide $ Hundered $ Hill)
90% Driver 10% vehicle(quote from drunk Navajo driver)
Free Chefj!!!
Scuba Drivers unite
BUSTY AND MY WEBSITE PICTURES FROM THE SUMMIT GET EM HERE
“Money can buy you a fine dog, but only love can make him wag his tail.”
Kinky Friedman
TrAiLbUs1 is offline
Old 01-20-2008, 04:33 PM   #4 (permalink)
FJ #8's Avatar
Member Number: 121
Nothing crazy at all. Do you think it will be ok to get to and from work till this weekend? Im thinking it should be fine? Where's cruiserlarry or Tcao at???lol
FJ #8 is offline
Old 01-20-2008, 05:00 PM   #5 (permalink)
ceejr's Avatar
Member Number: 7227
with out the shock or sway bar disconnected i don't see how that could possibly happen as you need quite a bit of droop the take the tension off the spring to get it to turn like that. it almost would have to be installed like that.
Titanium MT6 Conv Pkg Upgrade 2 Roof Rack OEM Hitch Predator steps Terk XM OME 885 Front springs OME 895 in rear Silverstar Headlights K&N air filter Nuvi 360 Hankook DynaPro MT RT03 285/70/17 Tundra black door handle Mod
ceejr is offline
Old 01-20-2008, 05:04 PM   #6 (permalink)
Garsgrl's Avatar
Member Number: 3187
I've had my suspension pop out of it's seat. I took a hammer and knocked it back into place.
Garsgrl is offline
Old 01-20-2008, 05:10 PM   #7 (permalink)
layonnn's Avatar
Member Number: 10006
My first guess would be some extreme articulation. But as you said, nothing extreme and mostly daily driver. Maybe someone borrowed the FJ and got some air with it.
Layton
2007 FJ Cruiser 5AT 4x4
Voodoo Blue
"God forgives...rocks don't"
layonnn is offline
Old 01-20-2008, 05:13 PM   #8 (permalink)
FJ #8's Avatar
Member Number: 121
maybe it was installed like that,but you would think i would have noticed it before now? I have had it on there for some time and this is the first time ive noticed something wrong.Thats why I plan on doing all my own install work from here on out.
FJ #8 is offline
Old 01-20-2008, 05:21 PM   #9 (permalink)
layonnn's Avatar
By "shifting" and the pictures i am guessing you mean that the end of the spring is not in the seat, correct? They could have been installed that way.
You could fix it yourself not too hard.
Lift the and put jack stands under the frame.
Unbol the bottom nut that holds on the shock.
Let the axle droop down and then the spring becomes loose.
You can then reposition the spring. Take maybe 30 minutes and save you some money if you have the tools.
If you lived here i would do it for you for 5 lbs of boiled crawfish.
Layton
Voodoo Blue
layonnn is offline
Old 01-20-2008, 05:30 PM   #10 (permalink)
FJ #8's Avatar
Member Number: 121
thanks for the info and offer, I am planning on doing it myself with my friends help. Do you tihnk its weird if it was installed like that to just be doing it now after Ive had it one there for over a year? Also do you think it will be ok left like it is till this weekend?
FJ #8 is offline
