Ok guys and gals here is the deal. I have 2 sets to work with.
I will ship you the new ones and after you install them you need to send me your old ones. if you would like to save on shipping and you have a way to cut them i just need the ends.
I will make them for anybody that would like a set!! If you bend them, which you're not going to, but if you do; ship it to me and i will replace it for FREE. I have done 5 sets so far and i have 2 sets on the shelf.
If you interested just PM me. Thanks for the interest
P/S bill i told you i would have them send down some yellow paint. For everybody else they are painted with truck bed liner, its a little tougher and looks very nice.
whats the cost? geez if i had the time i could make these easily
08 BLACK DIAMOND, OFFROAD PACKAGE,CQ,
MORE MODS TO COME IN THE FUTURE RIGHT NOW TOO BUSY SAILING THE SEVEN SEAS WITH THE NAVY!!!!!!!
You can bend anything with the right amount of gas pedal and lack of brain function
That is a great alternative for an upgraded rear link. Now its time to go use them as a skid
'76 FJ40 running on Propane.
1964 FJ45LV, 6.0L Vortec, 700r4, FJ62 split case, FJ62 axles, Power Steering, Spring Over, 35s, OD green. Metal Tech
The lowers are definitely stronger than stock. Don't know about the thickness of the OEM lowers, but will find out this evening, when I cut off the ends and brackets to send back to Chris (to use for someone else's newer set). I installed Digger lowers and uppers this past weekend.
Once I cut the old links, I'll try to get a shot of the thickness of the OEM tube and post it up.
Dennis' Titanium 'Bird of Prey': '08 Titanium 4X4; AT; LD; A-Trac; Uniden PC78XLT CB radio & K40 hatch-mounted whip; Yaesu FT-7800R dual-band HAM radio & Comet SSB2 hatch-mounted 1/4 wave antenna; Toyota extra horn mod; no mud flaps; LT285/70/R17 Hankook Dynapro MT tars; 3" Lift (OME 884 front coils & N140S shocks, ToyTech Medium rear coils, OME N71E rear shocks); All-Phase rear diff skid; SCUBA breather mod; Steel sway bar collars; All-Pro rear shock skids and lower link skids; Digger upper and lower rear links; Rasta4x4 skids; Toytec 1" diff drop kit (as soon as I get around to spacing the skids); Metal Tech step sliders; Mini-Me OEM roof rack; fender-mounted disruptors
Oh, I'm sure the OEM tubes are much thinner. Just tapping on one versus the other, it's like tapping a curtain rod versus a solid bar... it's that noticable.
