Old 03-13-2008, 08:10 PM   #1 (permalink)
Member Number: 9998
Clunk in front end fixed
About a month ago I installed a spacer lift to my FJ. After a couple weeks I finally got around to getting it aligned. The last week I noticed a slight clunk in the front end when I would back out of my driveway and sometimes when I was driving. After searching some posts on the forum I came across one where another member (sorry I can't give him credit as I didn't remember his name) had a similar noise, and it was after he had his FJ aligned. To get to the point, make sure your lower control arm bolts are tightened to 100 lb.ft. The bolts are the ones that the alignment shop loosens to make the adjustment on the lower control arm where it attaches to the frame. Mine weren't even close to correct torque. Failure to do this will cause this slight clunk. Hope this can help someone else.
Rcmoneypit is offline
Old 03-14-2008, 12:44 AM   #2 (permalink)
blackseabk's Avatar
Member Number: 7025
Re: Clunk in front end fixed
Thank you for the heads up, it is always good to know.
blackseabk is online now
Old 04-02-2008, 11:42 AM   #3 (permalink)
nlk125's Avatar
Member Number: 5310
Rcmoneypit previously said: View Post
Any chance of Pics of the offending bolts... I'm getting a front end clunk. Very noticeable after being parked, and first shifting into reverse, but also intermittently during driving. I've had Wheel alignments done so I suspect this could be the culprit. Thanks for the Tip, I'm going to check them out this week.
Cheers!
For those who "Get It", no explanation is necessary.
For those who don't, no explanation is possible.
nlk125 is offline
Old 04-02-2008, 11:47 AM   #4 (permalink)
JoeUser's Avatar
Member Number: 15334
Good to know. I've got to crawl under the FJ this Saturday (front diff drop install), so I'll re-check the torque at the same time...
Thanks for the tip...
'08 Titanium 4X4; AT; LD; A-Trac; Uniden PC78XLT CB radio & K40 hatch-mounted whip; Yaesu FT-7800R dual-band HAM radio & Comet SSB2 hatch-mounted 1/4 wave antenna; Toyota extra horn mod; no mud flaps; LT285/70/R17 Hankook Dynapro MT tars; 3" Lift (OME 884 front coils & N140S shocks, ToyTech Medium rear coils, OME N71E rear shocks); All-Phase rear diff skid; SCUBA breather mod; Steel sway bar collars; All-Pro rear shock skids and lower link skids; Digger upper and lower rear links; Rasta4x4 skids; Toytec 1" diff drop kit (as soon as I get around to spacing the skids); Metal Tech step sliders; Mini-Me OEM roof rack; fender-mounted disruptors
JoeUser is offline
Old 04-02-2008, 12:55 PM   #5 (permalink)
ballkillerxxx's Avatar
Member Number: 16315
Send a message via Yahoo to ballkillerxxx
good info will have to remember that when my time comes
08 BLACK DIAMOND, OFFROAD PACKAGE,CQ,
MORE MODS TO COME IN THE FUTURE RIGHT NOW TOO BUSY SAILING THE SEVEN SEAS WITH THE NAVY!!!!!!!
ballkillerxxx is offline
Old 04-02-2008, 06:13 PM   #6 (permalink)
plnfixr320's Avatar
Member Number: 14499
I have a 6" Rough Country lift, so my lower control arms have a lowering bracket . That being said the bolt that is circled in green is the stock alignment bolt in the new lift bracket. The bolt circled in yellow is where the alignment bolt should be on a stock or 3" lifted FJ. Hope this helps. This picture is taken looking from the front of the truck looking to the back on the drivers side.
07 FJC Ti.
All Pro Sliders, A/P Front bumper with small light hoop, A/P rear bumper, IPF's, 55w rock lights, Cobra CB, Bandi mount, 4' fiberglass whip on a spring, 6" Rough Country, 2" wheel adapters, 33" MTR's, LED mirror lights, a few LED's to light up the lower switch panel.
http://www.youtube.com/watch?v=9hW4HBt-OpA
plnfixr320 is offline
Old 04-02-2008, 10:59 PM   #7 (permalink)
nlk125's Avatar
Member Number: 5310
plnfixr320 previously said: View Post
PERFECT!!! Thank you very much for the PIC! I'm going under mine tomorrow to check it out.
Cheers!
nlk125 is offline
Old 04-03-2008, 03:52 AM   #8 (permalink)
plnfixr320's Avatar
nlk125 previously said: View Post
Cheers!
No problem
07 FJC Ti.
Old 04-03-2008, 05:16 AM   #9 (permalink)
fjTeddy's Avatar
Member Number: 4051
Thanks will be checking that today went to the shop an they couldnt find the problem thanks for the info.
fjTeddy is offline
Old 04-03-2008, 08:04 PM   #10 (permalink)
nlk125's Avatar
Member Number: 5310
So I crawled under there and Torqued away, then took it for a quick test drive... STILL CLUNKS. So I lubed the Driveshaft, spiders, and slip yoke, front and rear, then took it for a drive... Still clunks, or more accurately SNAPS... So it's off to the dealer tomorrow to have it looked at. OH!!! I still haven't torqued the wheels. I've heard that can be a clunking/snapping culpit too... I guess I'm off to do that now...
nlk125 is offline
