I asked something like you and CRUZINWYO responded me:
1- My question:
I just bought a trail team special edition, and it has Bilstein shoks. I want to lift the truck 2" or 2.5". In the front I will instal a T-Max winch with Lucrum mount winch. Could I use OME spring without changing the bilstein shoks? and wich spring rate should i buy for the front and wich one for the back.
2- CRUZINWYO respond:
You can, but I wouldn't. I have the TRD with the bilsteins shocks. I put longer coils on them and then found out that the shocks can over extend and break. So if you lift do an entire coil and shock setup that match...I recommend the entire setup to be the same brand all the way around. I would recommend the OME mediums all the way around for your application.
jonnie
3- What I did:
I brouthg the OME suspention kit, and sold to a friend the bilstain shock for US $400.00
