I just got off the phone with Camburg. I was told to never put anything on the uniball, as it will deteriorate the teflon. Also, if it starts to make noise, you can use white grease on it, but it is still frowned upon. In short, it is self lubricating and stay away from it.
I would say for the average less extreme off roader the uniball may not be for them if noise, squeeks and grunts are an issue.
Its one of those things that are an automotive tradeoff---one good thing for a new bad thing.
For example: more articulation along with more noise harshness and vibration In engineering terms> NHV.
The average less heroic driver may want to opt for the Specialty Products UCA which has a more OE style ball but tons of alignment adjustability.
Just my nickel.
2008FJ, AT, Black, Walker Evans adjustable remote front coilovers, UniBall UCA's, roof rack light bar, in-bumper Piaa fogs courtesy of SwissarmySUV's mount kit, factory type switches for lights sourced from other Toyotas, additional tranny cooler, inline Magnatech tranny and power steering filters, TRD cold air intake, Mobil 1 oil & filter
(coming soon: TRD supercharger & boost guage, driving lights, back up lights, decent interior lights)
Had Camburg's UCAs on my Tacoma and ran them "dry". They will only get worse with time. If you can't handle the noise and it will get old as will all the freakish looks you get driving around, mine got loud, then don't get them. They are a good product though and if you push your rig to its IFS limits then UCAs are a good piece of gear to slap on the rig.
TiTank and I went with the Light Racing (specialty products) control arms and are extremely happy. Perfectly quite, beefy as hell, and super adjustable. Mine are still in the garage as i'm waiting for my front suspension to arrive, but Don's are on and he loves em. Totally eliminated all the issues he was having with drift and bump steering. And they were able to get the alignment DEAD ON to factory specs. They rock.
Big Sigh...Wish I had read this earlier. I have been spraying the crap out of mine with WD-40.
WD-40 is not a good lubricant (regardless of what the website says) It is a water repellant and cleaner. The WD stands for Water Displacement. Plus it attracts dirt and grime, so you end up worse off than before you used it.
WD-40 is awful for uniball lube. It will collect dirt. Use a high quality thin, Teflon based lube, available at any decent mountain bike store. Wipe em off before and after trail runs. You don't need to drown them in lube. A little bit goes a long way. This info is coming strait from Total Chaos Fab, which makes an almost identical product with the same style Teflon lining.
"The early bird gets the worm, but the second mouse gets the cheese" --Steven Wright
07 BD AT 4x4/Swayaway suspension/Rasta, All-Pro, & All-Phase skids/Flowmaster exhaust/305-70-16 Cooper Discoverer STT's/AR Teflon Chambers/TC uca's/ ARB Snorkel/Extreme Limits Offroad Breather kit & snorkel head cover/IPCW tail lights/Fab4 Winch Bumper/ and more
