So I am looking for a slight bit more ground clearance than I currently have. I have the standard set of spacers (Lift and level). I think its coming in at around three inches or 2.5. I need to throw some new supsension under it, and was wondering if I could combine the OME suspension with the spacers to get around 4 inches of lift in the front? Has anyone done this or have ideas as to why it wouldn't work.
Too steep of CV angle = breakage. I have the OME 886's on my front and you can see in this picture that it is pushing the angles. Putting a spacer on this situation would do nothing more than push the CV angles too far IMHO...
Driver's side
Passenger side
Demello sliders
Demello rear bumper
Inchworm Lefty
ARB front air locker
Nitro 4.88 gears
Bud Built skids front to back
Super Swamper SSR 35 X 10.5
Safari Snorkel
Train Hard, Rest Harder
TLCA # 17784
It's interesting to me to see pictures of the axle with the 886's. I have the 883's and my axles are horizontal, which is better than stock, but nowhere near what MTBCouch shows in his pics.. Thanks for posting, that's a great illustration.
07 Titanium loaded..
Current mods: scuba breathers, OME883's & Bilstein513's, BFG KM2's, Bridgestone Revos, Trailgear Sliders, K&N Drop in, 08 side visors, 35% tint, Redline gear oil, Atrac hack, mini-ITX PC (GPS & wardriving), upgraded speakers, custom rear door sub, custom air dam w/ hella spots and surf rack, grill mounted hella driving and fog lites, air horns, solar batter charger, rear 12V outlet, block heater, painted stock alloys (1 set black, 1 set graphite)..
The 886's are heavy-duty, but that means the opposite of what you're thinking. They provide the most "lift". So, it's not sag but the opposite.
I hope that makes sense.?
I don't understand. If that is the case why does Toytec sell the OME kits with billet spacers? I notice they don't come with the suspension but it says you can add it.
__________________ '07 Black Diamond 4X4; AT; LD; A-Trac; OEM Roof Rack; OEM Skids; Blacked out Front and Rear
Future Mods: OME 885's; 285/70/17 BFG KM2's; Demello Sliders; All-Pro Rear Bumper; Garvin Adventure Rack w/ Air Dam
Correct me if I'm wrong, but I believe the Toytec front lift kit is a hybrid set-up consisting of Toytec's own spring (not an OME) with a spacer, combined with an OME shock.
