Hey guys.. I have a revtech 3in lift,,,, Just for the past month it has starting sqeeking.. Just the left front area where the shocks are and the spacer... What can i do, or maybe I have a problem???
Took it in the mud once, ever since,, SHE SQUUEEEKKKS non stop down the road
__________________ ~Andrea~
Current Mods:
~Aerflow light protectors black~
~Manik front guard~
~16in TRD wheels~
~Manik Tail light guards~
~Painted wings/bezel
~Bush Wacker flares installed and look good..
~RevTech 3 in lift~
~285/75/16 BFG AT~
~Manik light bar~
~Hella Black Magic lights~
Coming Soon:
~Procomp wheels~
~Borla duel Exhaust~
~TRD Intake~
~Paint door handles and mirrors~
~Coleman roof basket~
***AND THAT IS IT*** haaa
my fj is squeaking too but I have no lift I wonder what it is
Chefj's Little known facts: Thugasaur tracked down, strangled, and gutted the Snuggle fabric softener bear because he once had a towel that was...well...not so soft.
UBFM member #00 enforcer
"Church" V2.0
2007 Voodoo 5AT 4x4
______________________
AFE cai , kenwood excelon 889 , xm2go, piaa extreme super whites , demello front skid plate and rock rails and aero flow lens covers (THANKS GUYS!) , all-pro front sway bar links
My suspension started chirping after a weekend off-roading.
not sure if this related but I'm going to check if my springs are clocked correctly. They say if it's not clocked correctly then it will rub against the sway bar.
Well, that's what they say
My FJ Cruiser videos on YouTube and Vimeo
I added some steel collars to my sway bar (to prevent shifting left to right), and whenever they get dry the rubber squeaks as I bounce (even just a little bounce). I use a silicone spray to soak down the bushings and all is well; until they dry out again.
If that's not the problem, then use the same silicone spray on the upper and lower control arm bushings, and even the top of the struts (where the rubber attaches to the top).
Dennis' Titanium 'Bird of Prey': '08 Titanium 4X4; AT; LD; A-Trac; Uniden PC78XLT CB radio & K40 hatch-mounted whip; Yaesu FT-7800R dual-band HAM radio & Comet SSB2 hatch-mounted 1/4 wave antenna; Toyota extra horn mod; no mud flaps; LT285/70/R17 Hankook Dynapro MT tars; 3" Lift (OME 884 front coils & N140S shocks, ToyTech Medium rear coils, OME N71E rear shocks); All-Phase rear diff skid; SCUBA breather mod; Steel sway bar collars; All-Pro rear shock skids and lower link skids; Digger upper and lower rear links; Rasta4x4 skids; Toytec 1" diff drop kit (as soon as I get around to spacing the skids); Metal Tech step sliders; Mini-Me OEM roof rack; fender-mounted disruptors
noticed that my fj started to squeek a bit too. I have to OME lift but i dont think that has anything to do with it. Mayb my upper control arm or as said above swar bar bushing. Is silicone spray the best to use or some white lithium greese?
07 Sun Fuzion FJ 4x4
TRD Rims TRD CAI
Magnaflow Exhaust Pioneer Avic D3
20% Front Window Tint Oznium Dome Lights
OME 886/895 Lift Kit ScubaDriver
XM Radio Cobra CB Radio
285/75/16 BFG AT's
VSC On/Off Switch Atrack/Rear Locker Hack
Future: Rock Rails, Front Bumper? Roof Rack and Light Bar?
I had the same squeaks also .The silicone spray on allbushing points should do it!
I've just been noticing this on mine as well...I'll try this to at least see if that eliminates one thing the squeaking might be. Thanks for the information!!
__________________ 07' Black Diamond Upgrade Package 2 Mods:20 Tint, K&N Cold Air Intake, Flowmaster 40Series Delta Muffler, ToyTec 3" Lift, Wolo Bad Boy Horn, Scanguage II, PIAA Xtreme White Plus Bulbs, Thule Spareme Bike Rack
