Old 04-02-2008, 02:35 PM   #1 (permalink)
bcrib559's Avatar
Member Number: 17352
Ome Medium
OK, the lift is on order...... Ome Mediums all the way around.. I am throwing the pro comp flat blacks 7089 17X8 underneath also. A majority of people in this forum seem to be running 285/70/17 tires (32.7X11.2/17) I went to a local dealer and they have 4 fj crawlers with arb bumper and 886's. I test drove them and they all run 305/65/17 (32.6X12/17). I am not going to run a bumper with the mediums but thinking about butting the 5mm spacers ome provides on both sides to level the rake. I want these 305/65/17 's (Pro Comp Xterrains) they are nice! Just dont know if they will fit with the medium ome's.
I cranked the wheel both ways on the dealer truck and it clears those tires. I want to tooo. Any insight????????
bcrib559 is offline
Old 04-02-2008, 05:20 PM   #2 (permalink)
Member Number: 16339
Re: Ome Medium
iam thinking about doing the same thing how much for the lift and rims, tires.
viking1 is offline
Old 04-02-2008, 06:17 PM   #3 (permalink)
DoWork's Avatar
Member Number: 18372
Re: Ome Medium
I didnt know that dealers sold FJ's that had been modded like this. the lift is about 750 plus tires are around 1000.
-Mark
08' Black Diamond FJ. off road package, ARB roof rack, Kenwood DDX-6019, Gobi Ladder, OME lift!!
Wish list - BudBuilt skids, New shoes....
DoWork is offline
Old 04-02-2008, 07:10 PM   #4 (permalink)
my name is mudd's Avatar
Member Number: 17008
Re: Ome Medium
6000 for the bumper
5000 for ''crawler package''
and so on. check out the sticker
for a good chuckle. good luck with your set up
my name is mudd is offline
Old 04-03-2008, 10:16 AM   #5 (permalink)
bcrib559's Avatar
Re: Ome Medium
I am paying 700 for the lift 300 for install 760 for 5 wheels and 1025 for 5 of the exterrain tires. Total $2785 Dealer $8000.
But can some one answer my question? Do you think the 305/65/17 's will fit on the Medium ome front springs?
They clear great with the 886's I wont be putting on a bumper so it shouldn't bring the front down..... Might be the same height as the 886 with bumper?
bcrib559 is offline
Old 04-03-2008, 10:33 AM   #6 (permalink)
GTKrockeTT's Avatar
Member Number: 15581
Re: Ome Medium
bcrib559 previously said: View Post
bcrib...don't look for a definitive answer from the forum on this because we just can't tell you for a fact whether or not it will fit without rubbing on your vehicle.
a good majority of 2-3" lifted FJs run 285/70/17s, and even with this tire size, some rub some don't...just too many variables. and, the 305/65/17s are even wider. the bottom line is, there's a good chance it will fit without having any rubbing issues, BUT if you want to lift and stick on larger tires, please have it in the back on your mind that you just may have to chop those body mounts.
GTKrockeTT is offline
Old 04-03-2008, 10:39 AM   #7 (permalink)
NCFJ's Avatar
Member Number: 8585
Re: Ome Medium
I have the OME 885/895 lift with the Toytec 1/2"spacers on top, KM2s 285/70/17 on stock steelies, no rub at this point. The rub seems to be determined by the wheel used. Wheel width, backspacing and offset seem to be the key. I plan to do the body chop on mine just because I can and avoid any issues there.
I have also read where when using the wider rims like 17X9 rubbing on the UCA becomed an issue.
" "The next best thing to playing and winning, is playing and losing"
I live in typo hell, excuse the typos
Custom Steel fabrication-PM me
My FJ may be new, but this aint my first rodeo
My Front Tube Bumper
NCFJ is offline
Old 04-03-2008, 10:40 AM   #8 (permalink)
WyoOtto's Avatar
Member Number: 11698
Re: Ome Medium
This is probably not going to help you much, because I don't know what the offset and backspacing of the rims are... That said, the rule of thumb that I use (assuming you're going to wheel the truck a bit and not just ramp speed bumps) is that if the tire clears with no suspension upgrade, it will clear with a suspension upgrade. I say this because sitting in the truck and turning the wheel side to side is no indication of whether the tire will clear in a full lock and compressed scenario. I'm running 255/85-16s (33.1x10) and ran them without a suspension upgrade for several months. I DID HAVE TO CHOP THE BODYMOUNT. I am going to guess offhand, given the width of those tires that you will have rubbing in a locked and compressed situation, regardless of lift - at which point, you simply chop the mount.
Painted headlight bezel, Series 87 steelies with 255/85-16 Maxxis Bighorns, ARB full length rack, 60" hi-lift, OME Heavies on all 4 corners, Budbuilts front to back, OEM sliders, Scuba Driver mods, Upper and Lower rear Digger Links, TRD CAI, All-Pro High Clearance tailpipe, Hacked Rear Diff Lock, VSC on-off switch, Custom Expedition One Front Bumper, EPi 9000lb winch with synthetic line, and lots of manual recovery gear and tools.
WyoOtto is offline
Old 04-03-2008, 10:43 AM   #9 (permalink)
GTKrockeTT's Avatar
Re: Ome Medium
NCFJ previously said: View Post
it's not just the wheel used, although the backspacing and width do play a major factor as you mentioned. but, slight variations in the type of tire...AT or MT, the vehicle itself, alignment, all play a role in whether a setup will never rub, rub slightly at full lock and/or articulation.
Old 04-03-2008, 10:45 AM   #10 (permalink)
USMC_Sgt's Avatar
Member Number: 3297
Send a message via Yahoo to USMC_Sgt
Re: Ome Medium
The heavies aren't going to give you more clearance than the mediums. The difference in the two is the load it can carry.
GTKrockeTT previously said: View Post
x2 on that.. I thought it was anything over 295/70 you had to chop the body mounts. I believe the reason that so many run the 285/70's is because with that size you don't have to chop.
USMC_Sgt
07 FJC Voodoo
http://www.fjcruiserforums.com/forum...ue-raider.html
He has all of the virtues I dislike and none of the vices I admire.
-Winston Churchill
USMC_Sgt is offline
