Sorry for such a long post, but this is fairly complex.
Got the OME 885/ToyTec springs installed today, which were purchased as a kit from ToyTec.
Rear - No problems
Front ...When I arrived I was told that the FJ wasn't back from the alignment shop yet (a local Dodge dealer) and that they were having a very difficult time with it. The installation tech came back and said he had had a very hard time with the install to start with. Something about having to cut one of his tools (I assume the coil compressor) off with a torch when it got stuck/shifted during compression. ...but he finally got the front springs/spacers on. However, he was then fairly emphatic that the 885's were too stiff to be used with the stock Bilsteins and that the front Bilsteins were now over extended in his opinion. More on this further down.
Then they hit me with the really bad news...that it was going to be mechanically impossible to properly align my wheels/tires with this lift installed. The alignment shop told them that there wasn't enough camber adjustment to account for the impact of the lift. They said I could live with it, but I would go through a set of tires every year given that the camber was out so bad. They handed me a sheet which I don't really know how to read (I have attached it as an image).
So I immediately called Kirk @ ToyTec who sold me the springs. He said that there are lots of shops all around the country who have successfully aligned FJ's with this kit and that it was extremely difficult to advise on my particular situation over the phone, but offered to call the shop while I was there and conference with them, which we did. In the conference, Kirk again explained to the local shop his positive experience with the kit and offered to have the mechanical tech guru (I think he said the guy was the owner of ToyTec??) call my shop back. The call came after about 20 minutes. Whoever it was from ToyTec ran over the alignment numbers with the local shop guys and quickly concluded...drum roll...that there actually
may not be a problem!
IF ANYONE OUT THERE KNOWS HOW TO READ ONE OF THESE ALIGNMENT SHEETS, PLEASE OFFER YOUR OPINION. (not knowing anything...to me it seems like camber is actually within spec)
The unaccounted for variable seems to be front weight. When I bought from ToyTec I explained to Kirk that I had a RA Stealth/Titan on order and would eventually add a winch (total ~ 200lbs.)...and thus the recommendation for 885's. The local installation shop knows this (they had already agreed to accept shipment of the bumper and install it when it comes). ToyTec indicates that the additional weight will bring the front back down such that an alignment
with the bumper/winch will allow more camber adjustment.
And, that the additional front weight will compress the 885's enough that the Bilsteins should not be over extended.
So...it seems to drive fine. Stiff in the front, but that's exactly what I expected without the bumper/winch. And I can't detect any alignment issues simply by looking at the tires or during driving. I love the look and the extra clearance is exactly what I wanted.
...so...if you've actually read all of this and have some ideas/input/questions, please fire away. Am I going to be OK after adding 200lbs. to the front?
THANKS!
