Old 04-29-2008, 09:31 PM   #11 (permalink)
BobKid's Avatar
Member Number: 15682
Re: Installed SAW Hybrid Kit
Excellent! My hybrid kit was on my porch when I got home today. Hopefully it'll go on easily this weekend.
BobKid is offline
Old 04-29-2008, 10:10 PM   #12 (permalink)
DC Cruiser's Avatar
Member Number: 13963
The install is pretty straight forward. I did grind the sway bar and it is not contacting the springs at all as far as I can see. There was no noise at all after installing the SAW coilovers. The noise showed up the next night after installing the Rasta skids. Its the nuts that they use to hold on the controversial Scoop on the frt skid. They are contacting the sway bar. I put some spacers on it tonight and its better but still not gone totally.
I did have a bit of spring noise in the rear. I crawled under tonight and looked at the rear springs and the passenger side was not seated right on the top where it sits in the pocket. Jacked up that side to remove the tension and used a pry bar to slide it into the pocket and presto spring noise gone. Thats what I get for working in my driveway and at night I guess/LOL
Anyways alls good. and its Beer Time
Hopefully wheels will be in tomorrow.
GRAMPS TOY: 07 BD "C" Package, 5Spd Auto, Hood Deflector, Vent Shades, Pass. ArmRst, SS Grille Inserts, Black Tundra Handles
OFF ROAD MODS: ARB Winch Bumper, KC Daylighters, PIAA 510 Fogs, K&N Filter, 12,000 lb. Titan Winch w/syn line, SAW Hybrid Suspension (Metal Tech) Rasta 4x4 Ally skids, Pro-Comp 7028's (powdercoated white) & Goodyear 305 x 17 MT/R's, SpyderTrax Spacers.
FUTURE MODS:Rear Bumper, Aux Gas Tank, TRD SC,
ORIGINAL FJ:71 FJ4030 yrs ago) 350 Chevy V8 Conv., 4Spd GMC Truck Tranny, (IT BURNTUP)
DC Cruiser is offline
Old 04-30-2008, 09:03 PM   #13 (permalink)
Money Pit's Avatar
Member Number: 18399
Congrats on the new lift. Post those pics...want to check it out!
FJ-2007:Titanium Silver-4X4-A/T-Rear Diff Lok
Install History: TRD exhaust/K & N air filter/Warn rear bumper/ARB bull bar/Warn 9.5 XP/A-Trac/Sylvania Silver Star Ultra/Aeroflow HLC/Putco LED dome/17X9 MT/Cooper STT 285 70R17/DO Hybrid sliders/ICON Stage 2 Suspension (extended travel C/O)/ICON Lower Links/Total Chaos A-arm Skids/MAF 4+Plus Skids/Scan Gauge II
Miscellaneous: Hi-Lift/Warn & ARB recovery gear/Powertank #10 system/Staun 6-30 deflators/Halon & Dry chem/Tire repair kit
Money Pit is offline
Old 04-30-2008, 09:20 PM   #14 (permalink)
DC Cruiser's Avatar
Sorry guys have been busy at work the last couple of days. I have some pics and will try to post them tonight when I get home. Wanted to wait for wheels and tires to be on before I posted pics but hey what the heck I can show it with the stockers for now.
Old 05-01-2008, 02:42 AM   #15 (permalink)
mbarroso12's Avatar
Member Number: 11662
Im about to install some SAW coilovers w/ rasta skids. Could you post a pic of what is rubbing?
The early bird gets the worm, but the second mouse gets the cheese
07 BD AT 4x4 / Swayaway suspension / Rasta, All-Pro, & All-Phase skids / Flowmaster exhaust / 305-70-16 Baja MTZs/ AR Teflon Chambers / TC uca's
Waiting to be delivered: Road Armor Titan bumper
mbarroso12 is offline
Old 05-01-2008, 02:08 PM   #16 (permalink)
ballkillerxxx's Avatar
Member Number: 16315
Send a message via Yahoo to ballkillerxxx
sweet hope ya like it I will be purchasing SAW in the future why go Hybrid though vs the normal setup?
08 BLACK DIAMOND, OFFROAD PACKAGE, CQ,
WET OKOLE SEAT COVERS
HEAD UNIT ALPINE IVA-W205. BLACKBIRD PMD-200,
REAR VIEW CAMERA
EVERYTHING ELSE ROCKFORD FOSGATE
AMPS P200-2, P-400, 1500IBD. SPEAKERS
SUB T212D2, CAPACITOR 2.5 FARAD
MORE MODS TO COME IN THE FUTURE RIGHT NOW TOO BUSY SAILING THE SEVEN SEAS WITH THE NAVY!!!!!!!
:rocket
"Damn the torpedoes, Full speed Ahead"Admiral David Glasgow Farragut (1801-1870)
ballkillerxxx is offline
Old 05-01-2008, 09:20 PM   #17 (permalink)
DC Cruiser's Avatar
Mark form Metal Tech assured me that the difference between the SAW rear shocks and the OME shocks was nil. He said he has rode in both equiped FJ's and he couldn't tell the differance at all. So it boiled down to saving a few hundred bones that could be spent on other mods.
Old 05-01-2008, 09:35 PM   #18 (permalink)
DC Cruiser's Avatar
Quote : Im about to install some SAW coilovers w/ rasta skids. Could you post a pic of what is rubbing?
I will post a pic if I can. Its been raining and the area that is rubbing is kinda hard to get a picture of. If you look on the frt skid on what would be the topside of the skid you will notice 3 self-locking nuts which are used to attach the scoop to the skid plate. When mounted these nuts are touching the stablizer bar because the stablizer bar has been relocated with the stablizer bar spacers that you install with the SAW kit. I installed some spacers on the 2 mounting bolts towards the frt trying to lower the skid a bit. This has helped some but I believe I will maybe grind a little notch where each nut is contacting the stablizer bar.
I will do this when I remove the stabilizer bar again to grind some more off the area that Metal Tech recomends you remove to prevent the bar from rubbing the shock. I ground some off but by the looks of it not quite enough. So when you are doin the intall dont spare the grinder on that area otherwise you will have to remove it like I do and take more off.
Old 05-01-2008, 10:31 PM   #19 (permalink)
Member Number: 18296
I learned from Jacque at TOD that you should be able to fit a driver's license in between the sway bar and the coilover springs on each side. This requires some liberal grinding on the sway bar when using the SAW and Camburg coilovers.
2007 TOYOTA FJ Cruiser - Black Cherry Pearl with pinstripes
Done - K&N drop in, rear window mod, Hella FF's,
Demello Offroad hybrid sliders, Camburg coilovers - (700 lb./inch Eibach springs), OME 895E/N141 rear, CB/Bandi-mount, BFG MT 255/75 on 2nd set of alloys, Scuba Squad Mod all four breathers (AT5), front-to-rear mud flap swap
Fresh off UPS truck - DO skid plate
FJ's FJ is offline
Old 05-02-2008, 01:23 PM   #20 (permalink)
doesnt the SAW come with a sway bar bracket relocator of some sort?
REAR VIEW CAMERA
:rocket
