Re: for all the guys with the "FJ LEAN" and have used the OME spacer
survivorman previously said:
I had one that I got with my lift kit from metal tech....it was a small flat ring and it cost around $7 bucks I didnt throw it on because others said there would be no need........I am SPECIFICALLY looking for answers on this spacer......will it improve the lean, and is it ok to do seriously wheeling with this thing on
Yes it is there to fix the lean of the vehicle. ARB would not sell something FOR the purpose of going on their springs/struts if it was not okay to take offroad. I promise you.
Now don't go stacking 12 of those things on there though, just use one on the drivers side if you have measured a lean in the vehicle.
The height of the spacer does not correspond the the height of the lift you will achieve. A 1 inch spacer installed on the spring does not mean a 1 inch lift necessarily.
I have the OME heavy up front and medium in back.......anyone else with set up use the OME spacer and did it help level your FJ?
I have the same setup you have and I have the lean toward the driver's side also. It's very noticable to me but I'm anal about things of this nature. I haven't got a answer from anyone but I haven't ask for help on the forum. I plan on calling ARB this week to see if they can correct the problem. But if anyone knows the answer--let us know.
I have one spacer on the left front and it seems to be ok so far. I measuered the front after installing the lift and they were within .25". Has any one installed more than on spacer? The reason I ask I am looking at some day installing the Lucrum set up and don't want the front any lower.I was thinking about putting 2 on driver side and 1 on passanger side. Is this a bad idea?
_____________________________________________
'08 FJ Cruiser 5AT 4x4
Black Diamond
OME Lift 885/895
285/75/16 BFG AT
16x9 Axis Regulators
I have noticed my Fj leans to the left a bit.....and want to know has anyone added the little OME spacer on there lift and has it taken care of the lean issue at all? hard to imagine that a little half in spacer will correct the issue.....I think the spacer is a half inch.....anyways any info greatly appreciated
The OME "trim packers" are designed for coil springs, not the struts, so they wouldn't help. They come in 5mm and 10mm sizes so less than 1/2" max. The FJC has a slight lean from the factory, and is unlikely to have a major functional affect on the vehicle
This was the lean correction that resulted from installing the OME "trim packer" on the driver side front during the installation of my 886/896 "heavies."
The 5mm trim packers are different than the 10mm spacers. Neither of which are an inch - obviously (I hope). The trim packer (I know of one person running two trim packers on the driver side) goes on the driver's side strut under the spring seat (plate) to offset the lean. The 10mm spacers go on both struts on top of the strut plates to achieve greater lift. I'm running the heavies, both fore and aft and have one trim packer on the drivers side. I still have very subtle lean to the drivers side.
Painted headlight bezel, Series 87 steelies with 255/85-16 Maxxis Bighorns, BMC, ARB full length rack, 60" hi-lift, OME Heavies on all 4 corners, Budbuilts front to back, OEM sliders, Scuba Driver mods, Upper and Lower rear Digger Links, TRD CAI, All-Pro High Clearance tailpipe, Custom Built Rear Shelf, Hacked Rear Diff Lock, VSC on-off switch, Custom Expedition One Front Bumper, EPi 9000lb winch with synthetic line, and lots of manual recovery gear and tools.
Also, keep in mind that a single 5mm Trim Packer on the driver side front will not only raise the left front corner 5mm up, but it will also push the right rear corner down 5mm . . . . theoretically resulting in a total 10mm overall lean correction.
