I was having a rubbing issue but here was my solution
OK heres what I found out. I was rubbing hard on my front skid on the right side first off. I dropped the skid and shimmed it about a quarter inch and forward about a quarter inch also. now i got space there
next I adjusted the collar up a half inch for that extra one inch of lift and installed the AllPro ultimate adjustable sway bar links and extended them about a half inch longer than stock.
heres the compairison photos.
before adjustment with the rub
and now lifted with the longer links.
So far everything looks good. and the truck sits alot nicer now too. I'd suggest adjusting them before you install them or you will have to drop the tires and swaybar to readjust later. for a truly level lift adjust the collar up one half inch from the way they came on the passenger side, and a half inch plus about a quarter turn on the drivers side to get rid of the lean.
Not everyone is having problems with these so don;t let that deter you, My rig is just gor alot of bent parts and I think my swaybar may have been tweaked a bit. But problem solved!!
