I've had mine on ~front & Rear~ for about 2 weeks nowand love them,now I have never had a lift on anything before so my expertise is nill,but the difference over stock is amazing,I did not have the rubbing issues,no creaks or pops at all, even the alignment went off without a hitch...NOW I JUST NEED SOME NEW SHOES!!
__________________ ZOMBIE
'07' sil/ti
Mods..won't let me list them all
["To wish for peace;one must prepare for war" Ancient Romans
Yeah, I'd like to hear some too. Specifically off-road.
I haven't installed mine yet. I'm broke and want to get an alignment right after the install, so I don't mess up my brand new tires.
I would recommend letting the springs settle first, then get the alignment.
You can drive a couple of days without ruining your new tires, they'll be fine. I did so with mine after I installed my 3" lift, and everything turned out jake.
Dennis' Titanium 'Bird of Prey': '08 Titanium 4X4; AT; LD; A-Trac; Uniden PC78XLT CB radio & K40 hatch-mounted whip; Yaesu FT-7800R dual-band HAM radio & Comet SSB2 hatch-mounted 1/4 wave antenna; Toyota extra horn mod; no mud flaps; LT285/70/R17 Hankook Dynapro MT tars; 3" Lift (OME 884 front coils & N140S shocks, ToyTech Medium rear coils, OME N71E rear shocks); All-Phase rear diff skid; SCUBA breather mod; Steel sway bar collars; All-Pro rear shock skids and lower link skids; Digger upper and lower rear links; Rasta4x4 skids; Toytec 1" diff drop kit (as soon as I get around to spacing the skids); Metal Tech step sliders; Mini-Me OEM roof rack; fender-mounted disruptors
good point, just to add on to that, spring the extra bucks for a lifetime allignment. it's worth it. I like getting mine re alligned about every 3 months or if I get a pull from running a hard trail..
__________________ Ligten up, it's the internet.
air previously said:
Quote from: BigDouggieDoug
In the time between now and then, I'd probably drive ~150 miles.
It has been about 2 weeks since I did my fronts and I have not seen much if any wear. I have the Fox Coils and did UCA's as well. I would say you're probably fine.
