Old 05-14-2008, 02:47 PM   #31 (permalink)
RocKrawler's Avatar
Member Number: 3158
Re: All Pro FOX 2.5 issue's
Here is the correct mounting of the reservoir mount, there is a small seam bead thats less than 1/16" that will not affect the mount (the shape & mounting holes are a direct mirror of the Fox factory bracket, just the cups the reservoir sits in are repositioned). With this mounting position the hose bend will be tight but does not kink. Our hose dimensions are 1/8" shorter than the 11.5" spec Fox has (this includes the fitting to the centerline). and it does not kink.
RocKrawler is offline
Old 05-14-2008, 02:48 PM   #32 (permalink)
RocKrawler's Avatar
Member Number: 3158
Bodegas previously said: View Post
So AllPro... Is this reservoir location a design flaw or effed up install? Why is there not enough hose? I better not get this set-up in the mail. Waiting 3 months for this is fugazzi.
It is installation - not design flaw - proof is in the pictures!
Old 05-14-2008, 02:53 PM   #33 (permalink)
bandi's Avatar
Member Number: 2261
toyotaoffroadFJ previously said: View Post
i tried that.... they dont fit...theres a little bubble in the frames and it stops the braket from lining up to the frame holes......
By a 'bubble', do you mean a factory weld that is
a tad larger then the normal factory weld bead ?
a picture of this 'bubble' would be a great help...
The "Bandi Mount" Now By ALL-PRO OFF-ROAD
Phone:951-658-7077-Fax:951-658-2375-Email
bandi is offline
Old 05-14-2008, 02:58 PM   #34 (permalink)
JBIRD8403's Avatar
Member Number: 15604
Send a message via AIM to JBIRD8403 Send a message via MSN to JBIRD8403 Send a message via Yahoo to JBIRD8403
RocKrawler previously said: View Post
RocKrawler i PM'ed you
FOX Edition FJ Cruiser
2008 Sandstorm/4x4/AT/Pkg. Option E/Roof Rack/tow package/All Weather Floor Mats & Rear cargo
*Tint, Alpine IVA-W505, Alpine Nav, 8" Hertz sub woofer customized to fit in original enclosure, Audison amp, led dome lites, blacked out silver parts, Clifford lcd paging alarm
*FOX 3" Lift Fully Adj w/res, 2"stiffer rear springs from AP, also AP A-Arms
*33"-285-70-17 BFG A/T KMC/XD series 795 hoss black rims
JBIRD8403 is offline
Old 05-14-2008, 03:40 PM   #35 (permalink)
toyotaoffroadFJ's Avatar
Member Number: 13561
ok i managed it get it in there...but the passenger side is still screwed up....
heres some pics
as you can see on the passenger side i can only get 1 clamp one the bracket if i move it down on the other holder the hose will rub the spring
and as promised a pic of the adjustment...you must use 5/16 pin punches
toyotaoffroadFJ is offline
Old 05-14-2008, 04:08 PM   #36 (permalink)
RocKrawler's Avatar
Member Number: 3158
We have installed several with no problems, I will send you out a new set of brackets in case the mounting cups were welded on incorrectly. PM me your address and I'll get them out this afternoon no charge
