Old 05-13-2008, 03:30 PM   #11 (permalink)
Naughty's Manerator
TennesseeSquire's Avatar
Member Number: 3462
Send a message via MSN to TennesseeSquire Send a message via Yahoo to TennesseeSquire
Re: Keep stock 16" TRD S.E wheels with 6 inch lift
There is a simple answer, no. The factory wheels do not have the backspacing that is needed for a 6" lift.
My TRD wheels are the one thing I miss, since having the Rough Country 6" installed.
Terry
2007 FJ Cruiser TRD SE
My TRD Build Up
Trail Photos
TennesseeSquire is online now
Old 05-13-2008, 03:35 PM   #12 (permalink)
Naughty's Manerator
Member Number: 3462
DominicG previously said: View Post
I'd say a 3". Most anyone who does serious wheeling will say 3" is the maximum. Unless your TennesseeSquire (he just wheels that good). A 3" is that extra boost in clearance, without hurting your suspension geometry, and raising your center of gravity.
Unless you are damn a good driver, 6" is just to much if plan on wheeling. You do get a bonus in clearance.. but at the same time you don't. Your cross member is still in the exact same spot as it would be with 6" lift. Also you'll have the super high center of gravity, excess stress on all front suspension parts, and driveline (if you go with 35"s).
Thanks Dom
That is one of the reasons I don't run 35's, I currently on 305x65-17's BFG KM2's .
Terry
My TRD Build Up
Trail Photos
Old 05-13-2008, 04:00 PM   #13 (permalink)
fj6high's Avatar
Member Number: 17218
trailteamsfj08 previously said: View Post
After negleting my Cruiser and working on my other money pits for awhile; I am back on the FJ. So I have some Questions.
I'm at a loss between the Icon 3" Coilovers and the Fabtech 6"...
People that did 3" kits, are you getting enough ground clearance? Or should I do a 6" ? ....My biggest problem has been clearance.
Can I keep my stock 16" TRD wheels with a 6 inch lift?
I started with the OME 3" it was Just O.K. I wanted clearance, I went to the Fab-Tec 6" so I could put bigger wheels on the rims and lift the axles higher. The kit has a arched front cross member and small skid to protect the pumkin from damage without loosing any ground clearance. My rims are 12.8" wide and I can put some serious rubber If I like, throw in some spacers and I just added 8' overall width to the stance which in turn counters the High center of gravity!! Check out some of the Ultimate Four Wheeling videos. Every one runs 35"s are bigger with high lifts 6,8,10". You can not get any more clearance with your stock truck unless you put larger tires on and that can only be done with a Lift!!!
6" Fab Tech Lift, Bushwackers, 20" BBS wheels Nitto Terra Grappler 325/60/20 All Terrain tires. Spyder Trax 1.25 spacers Scuba mod, Manik tail light guards, Hunter GT807 full brush guard, Predator step bars, diamond plate interior trim, dual cd's, leather seats, Toyota Trail Team Badge.
fj6high is offline
Old 05-13-2008, 05:00 PM   #14 (permalink)
gon2srf's Avatar
Member Number: 6131
TennesseeSquire previously said: View Post
TS can you explain why the wheels don't work with your 6 inch lift? A different configuration of the steering knuckle?
Thanks.
TLCA#16768
33' BFG MUD's, Icon Front Coil Overs, OME Rear Shocks and Coils. ARB Bumper, Warn 9500XD winch, MAF Sliders & Skid Plates, Gobi Ranger Rack w/ PIAA Lights ft, rr, sd, w/Gobi Hi Lift, axe and shovel Mounts, dust lights. Dirty Parts Dual Battery System, Cobra 75 WX ST CB, Extreme Hi Lift Jack, Power Tank 10 lbs. CO2 System, All Pro HD LCA's, Custom Rear Drawers. Custom electrical.
Emerald Pacific Financial
949 235-1494
gon2srf is offline
Old 05-13-2008, 05:05 PM   #15 (permalink)
Naughty's Manerator
Member Number: 3462
gon2srf previously said: View Post
Thanks.
Yes, The RC kit comes with new knuckles that are almost double the size of the stock ones.
I don't know about the Fabtech's or Pro-Comp's kits.
Terry
My TRD Build Up
Trail Photos
Old 05-13-2008, 06:13 PM   #16 (permalink)
Member Number: 3240
Here is mine with the TRD wheels with 35's and the Icon 3in lift. They clear just fine with a body mount chop and a little bit bigger bump stop in the front. The rear rubs a little on one side on the plastic but could be fixed with some trimming.
I get all the ground clearence with all the performance of the suspension.
JDEMELLO is offline
Old 05-13-2008, 06:27 PM   #17 (permalink)
VooDude's Avatar
Member Number: 14197
Pro Comp's 6" requires an up-step to 18 inch wheels... or at least that's what the guys at 4WheelParts told me. I have OME and wouldn't change it for the world... OK... so maybe the Icons would be a little sweeter... or the Fox 2.5... OK, for my budget, OME is the BEST!
"JULIET" is my '07 VooDoo Blue 6MT Hybrid (Gas/Air) /Black Steelies TLCA#17788 / OME 886/895
GIBSON Exhaust / ARB Sliders / AP Bumper & Skid / Warn 9.5xp / Viking line & fairlead
AVIC-D3 / Viper / Alpine PDX-5 / Type R 6.5 Comp / Type R 6.5 Coax in PODS / WickedCAS w/ 2 10w1v2's
"60 percent of the time, it works every time."--Sex Panther Cologne
VooDude is offline
Old 05-13-2008, 06:34 PM   #18 (permalink)
Member Number: 11755
I am going to go with a 3" but I am undecided on wheel/tire size. I was leaning towards 17's with 33's but these 16's and 35's look good. Did you have to do any regearing, and how is the pickup on the freeway merge?
I know you can't have it both ways but being able to merge safely without lag in acceleration is important to me as mine is a daily driver. Feedback is appreciated.
Titanium, AT, Upgrade Package # 2, Running Bds, Leather Heated Seats
Mods: Alpine IVA-W205 w/Blackbird II. 2-Amps, 6 Speakers & Kicker VR 8" Sub in Factory Box.
JBA Headers, JBA CAT Back, TRD CAI
Planned Mods:
Lift & Tires, ARB Bumper w/ WARN Winch, Roof Rack
6MMFJ is offline
Old 05-13-2008, 06:35 PM   #19 (permalink)
gon2srf's Avatar
Member Number: 6131
JDEMELLO previously said: View Post
Jason- The FJ is looking might rugged and the beadlocks are outstanding.
TLCA#16768
949 235-1494
gon2srf is offline
Old 05-13-2008, 06:40 PM   #20 (permalink)
Member Number: 3240
Thanks, I'm going to do my own build up in a little while to cover all the stuff that I have done to it. I'm just waiting for it too be clean again so I can take some pictures.
JDEMELLO is offline
