Old 05-17-2008, 01:12 AM   #11 (permalink)
4XX4's Avatar
Member Number: 9918
Re: Suspension Mods - noises?
Yup. Sway bar being rubbed ever so slightly by my coilovers. Might quiet down if I file the point jutting out and making contact.
As for the rear shocks, they need ALOT of lube to stay quiet for say, a day or two.
Yes, it sucks but the ride and lift is so much better.
Blacksand Beast.
El Toro Rojo
http://www.fjcruiserforums.com/forum...toro-rojo.html
FJC Club ( Creepin' n Climbin')
Aloha FJ Cruisers (Wheelin' in paradise)
SoCal FJ Cruisers tag-a-long
4XX4 is offline
Old 05-17-2008, 09:05 PM   #12 (permalink)
Member Number: 16506
3 inch ome here no noises but my luck ill start hearing noises tommrrow.
Mods:
TRD CAI
TRD cat-back exhaust
Tinted front widows
Cobra (75WXST) 3' Firestik.
Piaa 520 Driving lights.
Total chaos skids.
Rain guards.
3 inch OME lift
MY BUILD IS DONE.
nissanaltimacrazyhorse is offline
Old 05-17-2008, 11:57 PM   #13 (permalink)
Member Number: 18296
A liberal application of the silty, slick mud we see in South Louisiana is a great silencer for all squeaks. The only squeak I encountered was on sway bar meeting coilover springs. Grind the sway bar per Mark Hawley's instructions and that squeak is GONE! Mud takes care of the rest.
2007 TOYOTA FJ Cruiser - Black Cherry Pearl with pinstripes
Done - K&N drop in, rear window mod, Hella FF's,
Demello Offroad hybrid sliders, Camburg coilovers - (700 lb./inch Eibach springs), OME 895E/N141 rear, CB/Bandi-mount, BFG MT 255/75 on 2nd set of alloys, Scuba Squad Mod all four breathers (AT5), front-to-rear mud flap swap
Fresh off UPS truck - DO skid plate
FJ's FJ is offline
Old 05-18-2008, 07:51 AM   #14 (permalink)
slither's Avatar
Member Number: 5147
Turn the stereo up and keep your eyes on the spotter. Noise happens! It's "snapping" breaking metal noise you should be concerned with!
2007 Titanium Metallic and YES I wheel it!
TLCA#16880, Gotham City Land Cruisers, Northeast Crew
RASTA Aluminum Skids
Daily Driver:2005 Toyota Tacoma C cab
slither is offline
Old 05-18-2008, 08:00 AM   #15 (permalink)
vhram's Avatar
Member Number: 15338
Ive driven a work truck for so many years that I dont even notice noises in the FJ, a/c on high and radio on = no noises.
2007 Titanium silver 4x4 AT
Warn front bumper
warn m8000
rear warn bumper
OME 3" lift,springs,shocks
bandi mount
magna-shields
OEM roof rack
OEM fog lights
All Pro rock rails
all Pro skid plates
oru light bar for roof rack
Hi lift jack,Titan air jack, air compressor
Predator tools shovel, pick, axe
taillight gaurds
Nitto Terra Grapplers
4 kc 6x9roof lights
Wet okole covers frt,rr
Fjammer, Dice,Ipod,subwoofer
Obtained but Not installed yet:
wiring for roof lights
Bigbillcombo
vhram is offline
Old 05-20-2008, 09:25 PM   #16 (permalink)
Wiz-of-Awd's Avatar
Member Number: 13502
When I added my custom trailing link skids all was good, until - about a week later or so I noticed some strange noises from the rear suspension. It seemed to only happen in certain instances, but nevertheless associated with the rear suspension mod. I say rear suspension mod because I had replaced the factory "rear lower control arm / front mount nuts & bolts with new ones." I did this to obtain the extra length in the bolts I needed for my install. Well, the nuts started backing off and I got some rotational noise in the hardware and skid assembly (creaking and groaning a bit).
All is good now, but the lesson here is to check and re-check your hardware after new installs and make sure all stays tight and in place. This is where most if not all of our "suspension mod noises" come from - at least for me.
A.W.D.
...an "AWD FJC" - '07 Titanium Metallic - 6 M/T (CQ, GY, UR)
http://members.cox.net/awdoriginals/images/misc/ico_awdfj.jpg
-- SAW RaceRunner Coilovers (front) / Shocks & Coils (rear)
-- Metal-Tech Step Sliders (with Line-X), Custom Trailing Link Skids (304SS)
-- AeroFlow HLC's, TRD Shift Knob
Wiz-of-Awd is offline
Old 06-03-2008, 10:38 PM   #17 (permalink)
outinthewoods's Avatar
Member Number: 15878
can you guys give me some recommendations on what grease/lubes to use?
do different parts (materials) require different types of grease/oil?? how do I know what to use?
Thanks!!!!!
'07 black diamond AT 4x4
Exp. 1 Front Bumper, epi.9s superwinch All-pro rock sliders, All-pro Ultimate links/skids ,ARB Full Roof Rack, IPF 868 and Back ups, PIAA bulbs, Cobra 74wx, bandi mount, lift; Old Man Emu HD, AR 17x8 Victor teflon wheels 285/70/17 Cooper Destination STT MT Two Dogs in the back
Scuba Mod
TLCA # 18519
outinthewoods is offline
Old 06-04-2008, 08:29 AM   #18 (permalink)
RocKrawler's Avatar
Member Number: 3158
Synthetic grease tends to be stickier & less prone to wash out, I personally use waterproof Green Grease & love the stuff.
For spray lube I prefer PB Blaster
- light years ahead of WD40 and also best solution for rusted nuts/bolts IMO.
For those having problems with the sway bar rubbing the coils, chances are your sway bar collars have loosened and the sway bar is shifting side to side, mine did along with many people on this board. The stock crimp on ring loosens (& sometimes falls off completely from what we've been told by customers) so we have a very inexpensive solution, remove or slide over he stock rings and bolt on these:
All Pro Off Road Sway Bar Collars; Only $19 each & its an easy permanent solution. Also helps your sway bar end links last longer by not allowing them to bind up when shifted over to one side when suspension is flexing off road
RocKrawler is offline
Old 06-04-2008, 08:50 AM   #19 (permalink)
oscarr's Avatar
Member Number: 7997
My rear end was making a light sqeeking noise.After I removed the rear sway bar & links the noise stoped.The rubber bushings suck on these Fj's.Sooner or later going to have to replace the front ones with better bushings.
ARB Bumper*OME Heavies*3" Skyjacker rear*Stock Steelies*Nittos Terras 295/70/17*Gobi Ladder*Cobra CB*AP Rock Sliders*Black Bezel*Real Wheels Light Bar*K&N Filter*Choped Body Mounts*Parrot Blue Tooth*Eliminated rear Sway Bar.
oscarr is offline
Old 06-05-2008, 05:47 PM   #20 (permalink)
my name is mudd's Avatar
Member Number: 17008
Give all your springs a good hittin with a rubber mallet from all different angles till they find there place. MOST of us are squeeking beacause our springs arent seated correctly. Lube and grease only works till the mud dries. For the rest of you idk.
my name is mudd is offline
