Old 08-07-2008, 07:21 AM   #11
FJBinky's Avatar
Member Number: 14848
Re: New Extended Length Bilstein Shocks Specifically for FJ Cruiser
Jbell previously said: View Post
I am at the highest setting on the front and have OME springs in the rear. The rear of my truck sits about 1.25 higher than the front and I have no rubbing issues or a body mount chop.
Are you running the swaybar relocate and/or longer rear brake lines?
Bilstein 5100 adjustables, Toytec rears with ProComps, Rasta front and center skids, Trail-Gear t-case skid, All-Pro high tuck tailpipe, Harbor Freight disposable backup light in the hitch, modified TT rear skid, SCUBA mod...
Which would you rather do, slide down a 50 foot razor blade or suck all the snot out of a dog's nose until their head caves in?
FJBinky is offline
Old 08-07-2008, 08:12 AM   #12
ZepG's Avatar
Member Number: 18546
I just had the toytec 3" kit with extended bilsteins installed and toytec never mentioned anything about an adaptor for the shocks. My mechanic said the only thing he didn't like on the kit was that the rear shock angle doesnt line up with the shock mount. Did toytec forget to send me the adaptor or do you have to order it seperate from the kit?
ZepG is offline
Old 08-07-2008, 08:14 AM   #13
FJBinky's Avatar
ZepG previously said: View Post
It depends on what shocks they sent you. The rear 5125s won't bolt up without the stem to eye adapter at the top.
FJBinky is offline
Old 08-07-2008, 08:32 AM   #14
ZepG's Avatar
I have that adapter on top, my mechanic said the bottom stud is at a different angle than the hole in the shock and is worried that it will wear out the rubber bushing. Did anyone else notice this?
ZepG is offline
Old 08-07-2008, 10:20 AM   #15
FJBinky's Avatar
Looks like the ProComp rears are the right way to go assuming that the ProComp part number I referenced is correct! 10.2" travel versus the stock 8.5" is nearly 2". Only the Bilstein 5125s allow the same amount of droop (with the adapter) but will be short on compression by an inch.
FJBinky is offline
Old 08-07-2008, 05:59 PM   #16
Jbell's Avatar
Member Number: 17995
FJuice previously said: View Post
Nope, I have swaybar collers in the front so hopefully my links won't break and my sway bar in the rear limits my droop so my break lines are not being stretched(I hope).
Yeah I definitely noticed, they were a son of a gun to get on that lower stud.
I guess only time will tell if the bushings wear out prematurely, I am pretty sure it will be fine though.
08' Black Diamond offroad package, Blacked out, scuba mod, vsc cancel switch,Magnaflow muffler and SS tip, ome 885 and bilstein 5100 up front, Ome 895 springs and Bilstein 5125's in rear, 285/75/16 Firestone Destination Mud tires,All-Pro transfercase skid, homemade Bandi mount,cobra cb,All-pro 1.5 wheel spacers, Hi-lift mounted on spare tire carrier, arb bumper,mile marker 9,500 winch, homemade snorkel....
Jbell is offline
Old 08-11-2008, 08:46 PM   #17
tisilverFJ's Avatar
Member Number: 1394
There is no difference in angle of the hole between stock shock or Bilstein. The Bilstein is just harder to get on. I've had mine on for over a year with no issues. The rubber bushing still looks normal. I'll add a picture soon.
TLCA#16292
Toytec- coilovers with custom rear coils,SS brake lines,front swaybar collars. PM me for TOYTEC Discountshttp://www.toyteclifts.com/index.php...id=84&Itemid=2
All Phase Offroad diff skid,engine skid,Hi-Lift mount,axe/shovel mount,HD LCA frame mounts.
Spidertrax spacers.
All-Pro HD LCA's,Bandi mount.
FabFours front bumper
tisilverFJ is offline
Old 08-15-2008, 06:04 PM   #18
FJCryptographer's Avatar
Member Number: 15298
Do extended shocks create more tension and downward drag on the rest of the suspension? In other words, by putting these on the FJ, are you not going to blow your CV joints, etc. faster?
Don't you be discontinuin' my FJ, mang!
FJCryptographer is offline
Old 08-15-2008, 09:33 PM   #19
FJBinky's Avatar
FJCryptographer previously said: View Post
The shocks under discussion on this thread are for the rear. I should have put that in the thread title. So no, extended shocks for the rear won't "blow" your front CVs.
With respect to the front, one sure way to overextend your front suspension and potentially damage your CVs is through the use of a 3" spacer lift. There are jounce stops for suspension compression, but the shock is the extension limiter. Adding a spacer to get 3" of lift means that your suspension can extend 3" further than it was designed to. Furthermore, the spacer lift will also mean that the shock will bottom out before you hit the jounce because it limits compression by that same 3".
FJBinky is offline
Old 11-17-2008, 04:09 PM   #20
jlmilligan's Avatar
Member Number: 23323
How is the road ride with the 5125s? I am trying to decide what to do with my backend. Thanks
jlmilligan is offline
