Old 08-06-2008, 01:23 PM   #1
FJBinky's Avatar
Member Number: 14848
New Extended Length Bilstein Shocks Specifically for FJ Cruiser
ok, I've done the search and can't find where this shock has been mentioned yet.
First, does anyone know what the stock rear shock length is fully extended and compressed?
Bilstein now offers an FJ specific rear shock absorber that is 2" longer than stock for those that have a lift on the rear. This shock does not require an adapter according to Bilstein's technical help line.
Part number F4-BE5-E703-H0
Extended 23.50"
Compressed 14.91"
Valving 128/105
Lift 0 - 2"
They also have another that will fit the FJ but is really for the 4Runner but this one is only 1" longer.
Part number F4-BE5-C514-H0
Extended 22.53"
Compressed 14.67"
Valving 128/105
Lift 0 - 1"
The following shock is the 5125 sold by ToyTec that requires an adapter. Keep in mind that you lose about an inch in compression due to the adapter but also gain an inch in extension for the same reason.
Part number F4-BE5-A463-H0
Extended 24.35"
Compressed 15.11"
Valving 255/70
One last shock is the Explorer ProComp ES9000 which does not require an adapter
Part number 92451X
Extended 24.70"
Compressed 14.50"
Valving unknown
According to Bilstein's Valving Quick Reference Chart 255/70 valving is "Performance-for aggressive high speed off-road" and 170/60 is for comfort for mid-size truck and SUV.
Bilstein 5100 adjustables, Toytec rears with ProComps, Rasta front and center skids, Trail-Gear t-case skid, All-Pro high tuck tailpipe, Harbor Freight disposable backup light in the hitch, modified TT rear skid, SCUBA mod...
Which would you rather do, slide down a 50 foot razor blade or suck all the snot out of a dog's nose until their head caves in?
Last edited by FJBinky : 08-07-2008 at 09:27 AM. Reason: Corrected ProComp part number
FJBinky is online now
Old 08-06-2008, 08:24 PM   #2
FJBinky's Avatar
Re: New Extended Length Bilstein Shocks Specifically for FJ Cruiser
Does anyone know what the stock rear shock length is compressed and extended?
Old 08-06-2008, 09:29 PM   #3
Gottagetone's Avatar
Member Number: 12336
I dont know the length but I do know that Toytec pushes the Procomp you mention above. They say they ride as good as anything at a much better price. I know a few guys with them in the rear and they love them.
“Since you have chosen to elect a man with a timber toe to succeed me, you may all go to hell and I will go to Texas.”
Davy Crocket
My Rig:
Gottagetone is offline
Old 08-06-2008, 10:03 PM   #4
mtnkraut's Avatar
Member Number: 15139
the bilstein 5100 is supposed to come out in the fall for the rear
FJ- Blue
mtnkraut is offline
Old 08-06-2008, 10:22 PM   #5
FJBinky's Avatar
mtnkraut previously said: View Post
I'm pretty sure that this is that shock absorber! It is FJ specific and shows as for a 2" lift. I'm just trying to verify for certain. See link below
Bilstein Electronic Catalog - 2" Lift FJ Shock
Old 08-06-2008, 10:38 PM   #6
Jbell's Avatar
Member Number: 17995
I just went and measured my stock rear shocks, 22.35" ext. and 13.85" comp. Don't really know how accurate my measurements are but I have the 5125's that Toytec sells and they are exactly 2"s longer than stock. I also have the 5100 adjustables in the front and couldn't be happier. They ride great!
Here are a couple of pics showing the articulation I am getting with the 5125's.
08' Black Diamond offroad package, Blacked out, scuba mod, vsc cancel switch,Magnaflow muffler and SS tip, ome 885 and bilstein 5100 up front, Ome 895 springs and Bilstein 5125's in rear, 285/75/16 Firestone Destination Mud tires,All-Pro transfercase skid, homemade Bandi mount,cobra cb,All-pro 1.5 wheel spacers, Hi-lift mounted on spare tire carrier, arb bumper,mile marker 9,500 winch, homemade snorkel....
Jbell is offline
Old 08-07-2008, 12:50 AM   #7
tisilverFJ's Avatar
Member Number: 1394
If your using Toytec's custom rear coils I would stay with the 5125's and adapter. The adapter makes it about 25.35" extended vs. the 5100 23.50 extended. If you don't like using the adapter go with the ES9000. Both are longer than the new 5100 coming out. The Toytec coil is 2.5" longer than stock. Last time I was testing mine, the Bilstein 5125 w/adapter still limited down travel some.
Here is another flex pic to go with the nice one Jbell added.
TLCA#16292
Toytec- coilovers with custom rear coils,SS brake lines,front swaybar collars. PM me for TOYTEC Discountshttp://www.toyteclifts.com/index.php...id=84&Itemid=2
All Phase Offroad diff skid,engine skid,Hi-Lift mount,axe/shovel mount,HD LCA frame mounts.
Spidertrax spacers.
All-Pro HD LCA's,Bandi mount.
FabFours front bumper
tisilverFJ is offline
Old 08-07-2008, 01:16 AM   #8
amaesing's Avatar
Member Number: 17795
NICE RIG, I MIGHT HAVE TO TRY THE 5125'S FOR THE REAR, ARE YOU STILL LEVELED OUT FROM THE FRONT? AND WHAT SETTING ARE YOU ON FOR THE FRONTS? ALSO ANY RUBBING ISSUES OR BODY CHOP? THX.
Jbell previously said: View Post
FJ TRAIL TEAMS SE / ICON 2.5 EXT COILOVERS / BILSTEIN 7100 WITH RESI'S / TC UCA'S / TRD CAI / MAXXIS BIGHORN MT'S / ALL PRO BUMPER / DEMELLO SKID / OTHER GOODIES
MY BUILD UP
WWW.AMAESING.NET
WWW.FLESHGEAR.COM
amaesing is offline
Old 08-07-2008, 06:17 AM   #9
FJBinky's Avatar
Thanks for the pics and info Jbell and TiSilver! I've got to get everything on order with Toytec!
Old 08-07-2008, 06:45 AM   #10
Jbell's Avatar
amaesing previously said: View Post
I am at the highest setting on the front and have OME springs in the rear. The rear of my truck sits about 1.25 higher than the front and I have no rubbing issues or a body mount chop.
Here is pic for you to see the rake with 5100's up front and OME lift in the rear.
Jbell is offline
