After reading multiple 'Alignment' threads my head is spinnin'! One question puleeze! I have OME 2-3 inch lift with BFG A/T's 285-70-17 on stock alum wheels. What front aligment specs are working best for this setup? Help?
I installed the 5100s giving me about 2" of lift up front. I took it to the dealer with a slight pull to the left. They returned it to me with a hard pull to the right. I went back a second time and recieved the FJ with a very slight pull to the right and the wheel sits slightly to the right.
Final specs:
camber .25L .035R
caster 2.79L 2.55R
toe .05L .02R
Do you think if I get them to drop the camber to 0 and raise the right toe to .05, my pull will go away?
as of right now, after the dealer having my vehicle in 2x since my lift(at which point, it went totally straight, i just wanted to make sure it was all good) every time it goes in, they mess it up worse, it started after the alignment pulling the wheel hard to the right, to the point that on a highway, you would be in the next lane w/i 4-7 seconds, i mean like you were changing lanes.
after the 2nd time, it still pulls the wheel to the right, as well as wanders right even on perfectly flat roads that do indeedd flood and puddle when it rains out.
i am pissed, cause they are now saying that my tires belts have shifted(ta-ko's, stock size, not offroaded) and they even crossrotated, in which case they damaged all 4 of my centercaps...
well, it drives like schit now, it was better when i lifted it and just droveit.
now my wheel has to sit at 1115-1130 just to go straight, and if centered, it goes wayy left, and if you let go, well, if i have to sneeze 3 times, by the 3rd one, im on the shoulder(just for reference...)
this sucks asz, i wish they would just gimme back my 70 bucks, so i can go elsewhere.
i even got a door ding last time when they had it all day.
'01Jetta turbo. loaded,sold x-mas eve. More mod money!!
'03chev 2500hd 4x4 crewcab,33s xterrains,locked leveled, 4.10s' traded for below, and it had heated mirrors. i miss em'
'07 FJ, bfg's, avs,t10001bd, 2-10in/w6-v2s, 4 farad cap, 0ga wire, more soon. acquired 10/7/06 lovin it
Everything I learned in life, I learned from watchin' P@rn... And while drinkin'.
oh, and no, i don't like to capitalise, unless i'm bored. so take it like the bicth u are
that sounds good, but i wonder how many times they will try it before coming up with excuses too...
oh, i forgot to say that they are now saying that it pulls cause it leand to one side, and that its cause i leveled it...
morephuckons i tells ya
too funny........from others on here they are happy with firestone, so I'm going to give it a shot.
I've done several alignments on fj's with lift kit both with and without upper control arms. All of them have driven straight the 1st time. I did mine more than a year ago and has no signs of abnormal tire wear. Also, none of the other fjs I have aligned seem to have any tire wear problems or pulling problems with the steering wheel at the 12:00 position. If you want to shoot me your specs on your alignments if you are having problems I can tell you where the alignment is going wrong.
I've posted a pic of my alignment report. This is for a 2" level lift spacer only. I have no idea what I'm looking at, but the green would lead me to believe they were able to get everything back within spec. The red shows that after the lift it did need to be re-aligned. Everything seems fine, it tracks straight and the wheel is oriented properly so I'm pretty pleased.
2007 Black Diamond | 6MT | 4x4 |Trail-Gear Sliders | BFG MT's 255/75-R17 | Icon 3" Lift | Camburg UCA's | Body Mount Chop | All Pro adjustable rear LCA's | Lucrum Winch Mount W/Light Bar | Hella 500 driving lights | Warn M8000 winch | Ramsey Wireless Winch Controller | Wet Okole seat covers | Yaesu FT-8800R | Garmin Nuvi 350 | Dog (co-pilot) |
