Old 08-28-2006, 02:49 PM   #1 (permalink)
Toyotatech1's Avatar
Member Number: 1637
Send a message via AIM to Toyotatech1
FJ Alignment Specs
2007
FJ Cruiser 4X2
FRONTSpecificationNeg. TolerancePos. ToleranceLeft Camber-0.57°0.50°0.50°Right Camber-0.57°0.50°0.50°Cross CamberLeft Caster3.57°0.50°0.50°Right Caster3.57°0.50°0.50°Cross CasterTotal Toe0.08°0.17°0.17°Left SAI12.92°0.50°0.50°Right SAI12.92°0.50°0.50°
2007
FJ Cruiser 4X4
FRONTSpecificationNeg. TolerancePos. ToleranceLeft Camber0.15°0.50°0.50°Right Camber0.15°0.50°0.50°Cross CamberLeft Caster2.82°0.50°0.50°Right Caster2.82°0.50°0.50°Cross CasterTotal Toe0.08°0.17°0.17°Left SAI12.35°0.50°0.50°Right SAI12.35°0.50°0.50°
When you get the alignment done the caster will more than likelly not go back to within specs. What you want to do is get camber as close to center as possible and have the right front caster be .40-.50* greater than the left side this will insure that the vehicle tracks straight and will have no tire wear issues as long as tires are rotated properlly.
Toyotatech1 is offline
Old 08-28-2006, 02:52 PM   #2 (permalink)
Member Number: 2552
Re: FJ Alignment Specs
Looks to me like something you would read from Space shuttle manual. Wouldnt you think the dealer who service my FJ has this info?
Thanks for taking the time to post though....I usually print out those info and leave in the glove box...
dau666 is offline
Old 08-28-2006, 04:04 PM   #3 (permalink)
Member Number: 1637
Any alignment shop can do this all they have to do is enter the specs manually the fj will not be on any programs yet. These are the steps to ahunter machine 90% of shops use hunter
Recall Vehicle Specs
Specs Databases
User
then enter specs
Old 08-28-2006, 04:18 PM   #4 (permalink)
bandi's Avatar
Member Number: 2261
Toyotatech1 previously said:
....and have the right front caster be .40-.50* greater than the left side this will insure that the vehicle tracks straight and will have no tire wear issues as long as tires are rotated properlly....
Is this due to Road CrossSlope or something to do with the drivers side siting 1/2" lower than the paserger side... or something I am not thinking of...
Thanks...
Leroy...
The "Bandi Mount" Now By ALL-PRO OFF-ROAD
Phone:951-658-7077-Fax:951-658-2375-Email
bandi is offline
Old 08-28-2006, 04:28 PM   #5 (permalink)
Not Serious
MissFJ's Avatar
Member Number: 1937
I would like to sticky this...but something tells me it should go in the wheel section??? am I wrong???
MissFJ is offline
Old 08-31-2006, 12:25 PM   #6 (permalink)
bigbill25's Avatar
Member Number: 1293
Here's my before and after:
After lifting but before the new tires and alignment, it felt fine.
After new tires, it was 'floaty' on the freeway.
After alignment, it was back to fine.
For Camber, that is all the could get with the lift...
--Bill
(Sold) 2007 FJ Cruiser, 6-Speed, Voodoo Blue, FE, CQ, UR, GY, CF, 3T, EL
Added: 2Q, 6D, WL, DH, V5, Bentup Sliders, Horn, CB, ToyTec Lift, Gobi Stealth Rack
bigbill25 is offline
Old 08-31-2006, 03:06 PM   #7 (permalink)
rsrd's Avatar
Member Number: 5231
Thanks...
Leroy...
I was wondering why my FJ was tilted to the left!!!!
rsrd is offline
Old 08-31-2006, 08:02 PM   #8 (permalink)
Jelopy's Avatar
Member Number: 898
Hey Bill, what did they charge you? I've got to get mine in somewhere tomorrow.
Voodoo Blue 4X4 with AT.
Added: Warn M8000, Factory rack, Factory hitch, Toytec lift (FJ3-FRCC), Amp-Fortyone-2 Black Alloy wheels with Nitto Terra Grappler 295/70/17, Cobra 75 WXST, Square Sliders, roof rack light bar with 4 Pro Comp lights, 2 Pro Comp lights on custom tube bumper, FJ battery clamp (Thanx Noisycow).
DIY Projects completed:
Toytec lift install, Sliders, body mount chop,Bandi Mount,hitch & tow ring, roof rack light bar and LCNW style bumper.
Jelopy is offline
Old 08-31-2006, 10:46 PM   #9 (permalink)
bigbill25's Avatar
Member Number: 1293
$50 or $60... Can't remember exactly. I probably could have got it for less somewhere else, but they are right down the street from work...
--Bill
Old 09-01-2006, 07:44 AM   #10 (permalink)
bandi's Avatar
Member Number: 2261
I Believe they all do tilt slightly to the left (driver side)... I believe due to the gas tank, transfer case front shaft output, front rear diff, Driver Componets (steering system, peddles, brake system) and some other items along the frame rail too... It all adds up !!!
I Set my own front when I did the lift, but I do not have a completly flat area to get it exact, So I will be going to a local shop I have dealt' with in the past with my big trucks... They let me in the shop and I can instruct the Alignment guy on what I am looking for, and no more... I only need the drivers side front adjusted to add a tad more positive camber... She drive straight, you can let go of the wheel and it does not drift, but I am noticing a little more wear towards the outer edge of the drivers front tire, all the other tires are wearing in the middle where I want it, so I just need to get this side at the same camber as the passenger side and I will be set...
bandi is offline
