I hate to keep relisting this problem, but I have done tons of reading and tweaking...and I still have a popping or clunk when I back up from a stopped position, or have my wheels cut. I have looked at my coils hitting my uca's... not it. My ball joints seem fine. My front drive shaft seems tight. Brakes are good, only 15k. I know others have the same issue because I have been following it on the forum. Has anyone come up with any answers? I know it has to do with something over extended from a 3" lift...that seems to be everyones common denomonater. It is killing me, it sounds like I drive some POS! Help!!
__________________ 2007 3" Skyjacker lift, 33x12.50x17 Pro Comp Xtreme All Terrains on 17x8.5 Pro Comp 7028, Trail Gear sliders, Swiss overhead console w/ custom light switches, All Pro front bumper with Warn 8000, Tuffy light bar with PIAAs, custom rear cargo storage box, Magna Flo exhaust, K&N FIPK, JBA headers
I have the same problem I think...dealership said its the break pads.. I have had it before on my dodge hemi... soon as I put in reverse it clunks or pops for a second..
Titanium Metallic - 4x4 - AT "C" package (canada)
Active Traction Control System , Rear diff lock
400 Watt / 115 Volt Power Outlet
Roof racks
Sirius Radio/Ipod
Garmin 60cx
Dude, if I were you, I would be very tempted to strap someone under that truck and don't untie them until they find where they noise is coming from. Looks like you have more than enough ground clearance for a child or small adult
"Any problem on earth can be solved with the careful application of high explosives. The trick is not to be around when they go off..."
buy a torque wrench and torque the LCA bolts to 100 ft-lbs. always works for me when I have popping. if that doesnt work are you sure your brake rotors and pads are fine? mine used to pop and I had them warrantied under the TSB (forgot the number).
also check the torque on your rear trailing arm mounts, they should be 95 ft-lbs. these will pop also and can sound like the noise is coming from the front.
4x2 black diamond, "Shadow"
1992 Ninja ZX7R K2
GOT PINSTRIPES?
TRD CAI, KC Daylighters, Kragen 7" HID's, Demello skid, PreRunner bumper, Gibson catback, ICON extended travel coilovers, ICON billet UCA's, ICON rear piggys, Kenwood sound system, Cobra CB. Black out door handles, mirrors, bumpers, bezel and rims. TRD floor mats.
Im willing to bet it's something other then the sway bar issue most seem to bring up. I have no swaybar and still get the annoying clunk/pop. I've checked everything out other then the brakes on mine. So, my bet is it is a brake issue.
It's not worth doing if you can't drop some f-bombs along the way!
Are you using a aftermarket skid plate? It's possible that your sway bar is contacting your skid plate when you back up. Another possibility is that your trans mount is broken or loose, you should get some one to get down next to truck when you back up to watch for it..
The problem you describe sounds just like what I have started experiencing this week. I noticed that it only started after getting my front end aligned at the dealership the past weekend. Tomorrow I am going to try tightening my front lower control arm adjustment bolts, because that is the only thing I can see possibly being changed recently.
