Installed my Rough Country lift last week. Went to Wheeltoberfest and wheel all weekend with no issues. I noticed that when I left work lastnight I noticed a little puddle about the size of a half dollar on both sides of my front diff. It is leaking oil on both side where the axles go into the diff. What the heck is going on. Does anybody have any ideas??
__________________ 2010 Trail Teams -Rough Country 6inch Lift
-Amsteel Blue Line
-All-Pro front bumper
-Warn M8000
-BFG 285/75/16 KM2'S
-Spydertrax
-Baja Rack
Re: After RC 6 inch lift my front diff is leaking????
Anyone???
-Amsteel Blue Line
-Warn M8000
-Spydertrax
-Baja Rack
Sounds like your leaking thru the seals, hope your still within your warranty range. My right side started leaking after I took it into a rock garden east Tn. It's just enough to keep the bottom wet but isn't dripping yet. Once you lift the front the stock angle of your CV's are changed at a greater angle causing more stress. I've benn running a big lift and I knew this would happen sooner or later.
__________________ Fabtech 6" Lift + OME 3" 20" BBS rims Nitto 35"s AT,1.25 spacers,Bushwhackers, VR3 The Toy Outfitters bumper ,55 watt fogs,TG sliders, Manik tailight guards, Stallion Light bar,55 watt Baja lights, Cobra 19 SXIV PA, Bandi 4' fire stick, K & N filter, Locker on demand, ATrac hack, VSC & DRL switches, TRD Cat back, Scuba Mod, Garmin Nuvi 200 BlueSeas 6 fuse Interior: leather seats, dual arm rests, dual factory DVD players, Diamond interior trim, Source 10lb, Rubber mats. TT and FJC Badge.
I am still under warranty. Is there a fix for this?? Good thing I work at a dealer..Hopefully
-Amsteel Blue Line
-Warn M8000
-Spydertrax
-Baja Rack
my front diff started leeking also. i took the front skid off to have a look. i found the bolts that hold it together was all loose. i tightened them and now it doesnt leak. im still wondering how they all came loose.
I don't drive I travel.
-3" FJ Lift Kit w/spacers and rear ToyTec coils
-Shock skids made by Fjtoyman
-Breather mod's half way finished
You might want to double check when I put my 6" kit on, the breather tube on the top of the diff pulled out and was leaking fluid. You cant really see the tube but if you reach on top of the diff near the driver side you can feal it. The rubber tube from the factory is not very long. I picked up a longer piece of fuel line from the autoparts store and installed some hose clamps in it.
__________________ RIG: MODS:
RC 6" lift-Radflo Coilovers-Custom Driveshaft-Spidertrax 1.25" spacers-285/75 R17 Nitto Terra Grapplers-Hella 500's-TRD Intake. Check out my Expedition Trailer Build: http://expeditionportal.com/forum/sh...ad.php?t=17905 http://www.fjcruiserforums.com/forum...trailer-4.html Want/Need List:
Highlift Jack Mount (Factory Rack), Driving/Fog Lights, Blue LED's, Bandi Mount, FireStik Antenna, CB, Navigation
