Go Back   Toyota FJ Cruiser Forum > Supporting Vendors > SwissArmySuv Products
Old 02-19-2008, 07:24 PM   #381
SwissArmySuv's Avatar
Member Number: 1693
Re: Overhead Maplight Kit
dubai previously said: View Post
this is mine before and after installing
great job! thanks for the pictures from Dubai.
Rick Rock previously said: View Post
I have decided to mount my roof light switches there (three of them). I'll post pictures when done.
Anxious to see this one!
Mr R2FJ previously said: View Post
hurray, thanks swiss!!
You are very welcome!
SwissArmySuv is offline
Old 02-21-2008, 09:03 PM   #382
Regud's Avatar
Member Number: 14560
I got my kit today and had some free time, so I decided to install it. I went ahead and ran a cat5 extension cable to the console; my scanguage is being delivered tomorrow. Here are the pics of where I ran the cable and the install.
I was a little nervous at first with such long and detailed instructions, but the install went quick.
Thanks Swiss!
Regud is offline
Old 02-22-2008, 11:39 AM   #383
CactusJK's Avatar
Member Number: 1157
Swiss- I was thinking that a great addition to your standard setup would be two small LEDs aimed down like in the LEXUS GX470. The tiny LEDs provide just enough light to see the area around the shifter. Not sure how hard this would be to retrofit? Seems like many new cars have these LEDs.
CactusJK is online now
Old 02-22-2008, 03:56 PM   #384
Member Number: 1693
CactusJK previously said: View Post
Actually, I think that would be easy to do and also a very good idea.
One thought might be to keep the main lights as they are (3 led hi-itensity) and then add 1 or 2 smaller single red leds for focused console lights.
You could easily get power from the existing line you ran for the mini-console and add in a switch.
Maybe something like this (prewired and ready to go)
Waterproof MicroStar LED landscape and interior lights. 3mm LED in Stainless Steel case.
Old 02-22-2008, 08:39 PM   #385
CactusJK's Avatar
Member Number: 1157
Exactly! I definitely want to keep the original 3LED lights and add these. Maybe you can experiment and let us know the best way to retrofit?
SwissArmySuv previously said: View Post
Old 02-23-2008, 09:13 PM   #386
Member Number: 1693
here is what you need to do:
1) get the lights you want and switch if desired
2) choose your method of connection per below
Note: on option #1 there is a "3-wire ribbon" you would tap into and the "door" tap is the center wire
Old 02-27-2008, 09:38 AM   #387
Member Number: 16365
Does this also work if I want to hook up the map lights to come on when I open the door? Or is it different?
jefferson is offline
Old 02-28-2008, 08:28 PM   #388
Member Number: 1693
jefferson previously said: View Post
yes it would. just take the red lead from the map light kit and connect it to the tap location in place of connecting it into the fuse block.
Old 02-28-2008, 10:01 PM   #389
how would I go about making this "tap location"? Sorry...never done this kind of stuff before. Would the switches still work if it was hooked up to come one with the doors? Thanx!
Old 03-02-2008, 09:46 AM   #390
Member Number: 1693
I had kind of re-thought the "door controlled option" a little yesterday and came up with some ideas on a little better option if someone were really serious about converting the "Swiss" map lights to function more like the dome lights (i.e. have the map lights come on and off with the doors and also have the option of turning on the maplights when the doors were closed).
The thoughts I came up with would require an additional tap (as shown in one of the previous posts and below) and would require changing the switches to 3-position switches. This would take quite a bit of conversion to accomplish, but there may be some folks wanting to consider it.
However, a word of warning: I selected the switches I use for several reasons, but the foremost were the overall size and the right angle terminals. They have the lowest profile I could find, plus they have a very long life expectancy. The type of switch I mention in the following is larger in diameter, protrudes into the housing further and the terminals face outwards instead of at a 90 degree angle. The following are just ideas and should work just fine, but I did not build a unit and test it. Also, the terminal size on my switches are .110" wide, most rocker switches are .187" wide.
Ok, here we go ..
To be able to have a multi-function light (i.e. have it come on and off with the doors and be able to turn it on while driving), basically requires a 3-position switch (like the dome light) .. doors/off/on. The bottom diagram below has just that .. a SPDT (single pole/double throw .. on-off-on) switch.
You also need (2) sources of ground .. door ground for "door mode" and auxiliary ground for when you want to turn the map lights on when the door is closed. The one thing you need to understand is the "door ground/power". The "3-wire ribbon" tap (center wire) functions differently during the (2) modes. It acts as a positive (12v) line when the door is closed and it acts as a negative (0v) line when the door is open. What the diagram below does, is this .. when the doors are closed, the leds grab power from a standard 12v source and use a separate ground to make the leds work when the switch is in the "#1 position". When the doors are open and you wish to have the leds come on with the doors, the switches must be in the "#2 position". When in the #2 position and the door is open, the center lead of the 3-wire ribbon acts as a negative and the leds are on. The last thing I mention is this ... some of you may wonder, "when the switches are in the #2 position and the door is closed, the center lead tap in the 3-wire ribbon is 12v (positive) feeding into the light and there is a second power going into the light (the 12v fused power). Would this "blow up" the light bulb? The answer is pretty basic and I have said this before, think of it in this fashion .. hook a garden hose to a faucet; hook a second garden hose to another faucet; connect the (2) hoses to each other; and turn on both faucets. Basically they cancel each other out and no water flows (i.e. the leds are off).
To do this type of a conversion you would need:
(2) SPDT switches (on-off-on) (similar to Del City # 7900071)
(6) .187" female terminals
(1) tap slice
(5-6 feet) of #18 wire
You would also need to modify the housing for the new switches, make various lead wire connection changes, and make a tap into the overhead dome light 3-wire ribbon (the most convenient location would be in the driver's side a-pillar).
Here is the "old" (top) and the "new" (bottom) basic diagrams.
If the question arises .. I don't think I would offer this as an option.
