Go Back   Toyota FJ Cruiser Forum > Trail > Trail Use, Safety, and Education
Old 06-20-2006, 03:31 PM   #21 (permalink)
Plum Crazy's Avatar
Member Number: 1414
Re: Crossing Rivers and Streams
are all the threads the same on both front and rear diff, tranfer case, and transmission or are the different. Has anyone done all 4 breathers if so could you post detailed info thanks.
Plum Crazy is offline
Old 06-21-2006, 06:29 AM   #22 (permalink)
Thai's Avatar
Member Number: 1669
The front diff is in the engine bay on the driver's side of the engine block. The other breathers (tranny & TC) are together i think...see this link: http://www.toyota-4runner.org/showth...ight=breathers.
The only one that is easy to do (and most important) is the rear axle breather. The other ones are OK where they are at. If you flood the other ones, then you have gone way too deep!
www.toyota-4runner.org or www.t4r.org
________
|_l__[ ̭̭̯ _],_ ̭̭̯
l----L- 0=*=0
()_)--()_)--)_)
Off-roading Videos of My G
Thai is offline
Old 06-21-2006, 01:44 PM   #23 (permalink)
Plum Crazy's Avatar
Member Number: 1414
When i went to buy the parts they want to know what the threads are in the factory breather, so it will thread in and not strip out the threads on the differential does anyone know the exact thread size and also is there a specific size hose that is needed
Old 07-09-2006, 02:06 AM   #24 (permalink)
Banned
Cptn. Wacky's Avatar
Member Number: 3656
Id like to stress the Tread Lightly train of thought here if i may hold a sermon
Dont be all runnin around like your in a mitsubishi comercial and driving over random hills and through streams. stick to the path and if you have to cross a stream do it at a place in the trail. If you have to cross in a non trail area
then pick the shallow spot ( get out and walk it with a stick in hand )
know how high the intake is and dont go anywhere near that mark. drive slow and steady to a pre-thought out exit, driving slow and steady keeps down wheel spin that can hurt the enviroment/fish/keep from gettin stuck, also this makes a wave infront of the truck so that the wave actually pushes the water from infront of you.
again dont cross streams if you dont have to. exhaust, fluids and such can
hurt bambi later. wait i shot bambi. you get the point
Cptn. Wacky is offline
