Go Back   Toyota FJ Cruiser Forum > Trail > Trail Use, Safety, and Education
Old 09-06-2006, 12:04 AM   #11 (permalink)
bigbill25's Avatar
Member Number: 1293
Re: Here is why part time 4WD should never be used on dry pavement
MauiJim previously said:
EDIT: Gah, ^^ bigbill beat me to it!
You have to be quick on the post around here! Welcome to the crew, MauiJim!
--Bill
(Sold) 2007 FJ Cruiser, 6-Speed, Voodoo Blue, FE, CQ, UR, GY, CF, 3T, EL
Added: 2Q, 6D, WL, DH, V5, Bentup Sliders, Horn, CB, ToyTec Lift, Gobi Stealth Rack
bigbill25 is offline
Old 09-07-2006, 08:26 AM   #12 (permalink)
Hotrodguru's Avatar
Member Number: 3108
Send a message via ICQ to Hotrodguru Send a message via AIM to Hotrodguru Send a message via MSN to Hotrodguru Send a message via Yahoo to Hotrodguru
MoSun previously said:
I know this has been brought up before, and some still might argue that you can drive your part time 4x4 on pavement under certain conditions.
I ran onto this link a long time ago but forgot where. Lucky for me and our forum members I found it again.
Follow this link http://www.4x4abc.com/4WD101/driveline-bind.html for a good example of what can and probably will happen to your ride if you do think it's ok.
MoSun
I think the original post or question brought up was whether you "could" not "should you", especially in adverse conditions. You can't compare the gearbox out of some older model vehicle to a newer updated one.
Don't get me wrong, I don't think a trip from Houston, TX to Phoenix, AZ in my part-time 4WD FJ in 4H is a good idea regardless of driving conditions. But if the roads are way crappy or I'm driving 20 plus miles on isolated gravel/sandy on or near our land near Mexico City I'm going to be in 4H.
Heck I did it in my Grand Cherokee with over 80,000 miles on it ALL the time. Especially while looking for some good surf spots in Mexico on way crappy roads.
Guess I'll wait for the I told you so's.
FJoel previously said:
Nice link! Seems like a no brainer to anyone who actually wheels and likes to know what is going on inside/under their vehicle. MUST READ FOR NOOBS or SMART @SSES.
Exactly, hey some of us actually wrench and have a general understanding of how things work. Doesn't mean we won't disagree.
http://www.revo1.com/subbietranny/
P.S.
Ohh yeah, a majority of the binding in wheelin occurs while turning, especially with a tighter turning radias.
Hotrodguru is offline
Old 09-07-2006, 09:58 AM   #13 (permalink)
East Coast Moderator
Bostonian1976's Avatar
Member Number: 333
that's why I'm glad to have full time 4wd.
But..same thing can happen with your center diff locked in a full time 4wd right?
MT6 Titanium
Wanting TRD wheels
'67 Land Rover Series IIa
Speed Demon!
' 65 Land Rover Series IIa
Bostonian1976 is offline
Old 09-07-2006, 10:10 AM   #14 (permalink)
rsa
rsa's Avatar
Member Number: 557
This is a repost, but what the hey :-)
Tire air pressures vary. Tire wear differs. Tires end up with slightly different diameters. Roads aren't always as straight overall as they seem.
Pretend the front tires are 31.5" in diameter.
Pretend the rear tires are 31.4" in diameter.
A tire 31.5" in diameter travels 8.246680715673 feet in one rev.
A tire 31.4" in diameter travels 8.220500776893 feet in one rev.
Drive your manual mandated monthly 10 miles in 4Hi.
The 31.5" tire turns 6402.5759963825 revolutions.
The 31.4" tire turns 6422.9663657980 revolutions.
The rear tires experience twenty revolutions more than the front tires.
No, that's not the real world, tires aren't round and I've ignored significant figures. But it's enough for me to follow the recommendations of an owners' manual and leave a part-time transfer case in 2WD on the pavement. My 2¢.
YMMV
©2007, 2008 rsa
rsa is offline
Old 09-07-2006, 10:49 AM   #15 (permalink)
philipl's Avatar
Member Number: 3415
The picture is of a blown Chrysler transfer case. Somehow I think Toyota is going to hold up much better. I agree that driving a part time 4x4 at 70 in 4H is foolish. I also think that Toyota knows what it's doing and the manual does not sya to take it off road before engaging 4H on a monthly basis.
philipl is offline
Old 09-08-2006, 08:54 AM   #16 (permalink)
highbeams's Avatar
Member Number: 1769
that is not a Chrysler Tcase, it is the tcase they put in jeeps however, and yes they can end up like that. However to get into that shape I believe the torque reduction of 4 low would more than likely have to have been used. Another big factor is several companies make a 4 to 1 ratio for that case, the np231, which is engineered for a much higher ratio, 2.61 to 1 I believe. They make another case that is engineered for a 4 to 1, which is used in the rubicon, Since the Ruby came out in 03, a lot of guys have been throwing 4 to 1 gears in the 231 and having splitting problems.
Now. as I have mentioned, I have run highway speeds in 4 high on dry pavement in several different machines, without ill effect. I do not do it because I want to see broken parts, but because **** happens. I think being so scared of something can be more negative than not fearing it. Yes there is benefit to running a few miles once a month in 4 high, being to scared to do it could be worse.
Full of life and loving it.
Save the cactus
highbeams is offline
Old 09-08-2006, 08:55 AM   #17 (permalink)
highbeams's Avatar
Member Number: 1769
qua77ro previously said:
TJ: highbeams, where was that picture taken?
SBNF
Save the cactus
Old 12-12-2006, 11:43 AM   #18 (permalink)
White Rim's Avatar
Member Number: 3435
"windup" is less of an issue with transfers with coaxial driveshafts such as the FJ40, because no bending moment is applied to the case.
White Rim is online now
Old 12-12-2006, 11:51 AM   #19 (permalink)
1 Bored Clerk's Avatar
Member Number: 741
1911 previously said: View Post
Someone should tell Toyota, since that bastion of liabilility-avoidance the owners manual says to drive it in 4WD for at least ten miles every month.
With the understanding that you follow the other recommendations in the manual for transfer case usage...mainly, don't drive in 4wd on dry pavement.
Take it on a dirt road and drive in 4h. If you aren't doing 10 miles a month in the dirt, worrying about your transfer case and front diff getting lubed up probably aren't much of a concern.
1 Bored Clerk
Inchworm Gear E-Locker Guard
1 Bored Clerk is offline
Old 12-12-2006, 05:58 PM   #20 (permalink)
rsa
rsa's Avatar
Member Number: 557
I was surprised with the wording of the OM also.
Four−wheel drive system (part−time four−wheel drive models)
“H4” (high speed position, four−wheel drive): Lever at “H4” Use this for normal driving on wet, icy or snow−covered roads. This position provides greater traction than two−wheel drive.
You should drive in four−wheel drive for at least 16 km (10 miles) each month. This will assure that the front drive components are lubricated.
So if the roads are wet, go ahead and put in it 4Hi?! So says Toyota.
©2007, 2008 rsa
rsa is offline
We operate more than 100 automotive forums where our users consult peers for shopping information and adv
