Transmissions / Transfer Cases / Traction AidsThis area is for discussion, questions and problems with the FJ Cruiser's gear train, including topics on A-TRAC, VSC, locking diffs, gear ratios, manual vs. AT, etc.
I went bouncing around offroad and my battery clamp broke...my battery slid over and cracked my upper tranny hose right where it connects into the radiator....i lost quite a bit of fluid before i discovered the issue....i cut the hose an inch shorter and reattached it to get home.....it is low on fluid because it's not shifting properly.....here's the problem....i can't locate the tranny dipstick or where to add fluid!!!! I searched thru pages here but only found a discussion that it is a sealed system....is this correct?? then where do i add fluid???
2007 TRDSE
ZORT
you don't have a soul you are a soul you have a body
Same thing happened to me a couple mounted ago. Had to get a tranny flush. I don't suggest doing it yourself. There is a special procedure for it. If you mess it up you could ruin your transmission. I believe it's added from underneath and pumped in.
thanks guys...i found a youtube video for an 07 Tacoma and it was added underneath and it only has an overflow plug so kinda sounds the same with this (the FJ)....
Recently found out it's the same way on a friend's 4.6L Tundra. It is kind of freaky not being able to check it...
__________________ The stitched-together quilt of your stony silence forms a tapestry of quiet desperation- Dr. Orpheus
The SANDWORM - Just another 'ol 2008 Sandstorm 4x4 5AT KF5UOV - Technician Class Help Find the Solution to Fender Failure
Once you pull the FILL plug, you just stick a long clear vinyl tube into it (it will stay in) and run the tube up to the back of the engine, stick a small funnel in the tube and it easy to fill and no spills. Just make sure the tube is away from catalytic convertor.
DEWFPO
sweet....i'm wondering if i should just drain what's left and refill it all....has to (should) be Toyota fluid right?
I would. You're going to be down there to pull the FILL plug anyway, you might as well pull the DRAIN plug. When I pulled mine on the original factory fill, I got 3.1 qts out (hot).
Toyota Type WS, Amsoil Type ATL, Redline D6 (last time I checked the D6 didn't mention it was Toyota Type WS replacement, but it used to say that).
DEWFPO
