Mystery bearing?!? - Page 6 - Toyota FJ Cruiser Forum
» Auto Insurance
» Featured Product
Old 11-30-2012, 09:58 PM   #51 (permalink)
71roadrunner's Avatar
Member Number: 28675
Re: Mystery bearing?!?
Here's a couple pics of the inside of an intact bell housing showing the quill surrounding the splined transmission input shaft. Top pic also shows the clutch release fork and TO bearing. Lower pic shows only the release fork (also visible is the wear damage on the quill).
71roadrunner is offline
Old 11-30-2012, 10:38 PM   #52 (permalink)
CowboyCEO's Avatar
Member Number: 12784
Send a message via Yahoo to CowboyCEO
That looks very neat and tidy.
Here is what mine looked like at the first look inside.
Zed? Zed is dead But "9-Ball" will roll again!!
2,007 Sun Fusion / nickname "9-Ball" / Black Leather / K/N filter / Safari Snorkel / Flow master 40 series / 6sp M/T / Hella 550's / Ricochet Skids / Demello sliders/ Boztec diff skid, High Lift hanger and antenna mount / Fire stick / Uniden c/b / Glade Plug-in / Nitto Terra Grappler 285/70/17/, Fox 2 1/2" ext-travel coilovers with resi up front and Fox 2.0 piggybacks in the rear/ Total Chaos U.C.A.s/ Icon springs / All Weather Mats...
<a href=http://i580.photobucket.com/albums/ss245/cowboyceo/MrSpinnerScores2.jpg target=_blank>http://i580.photobucket.com/albums/s...nerScores2.jpg</a>
CowboyCEO is offline
Old 11-30-2012, 11:02 PM   #53 (permalink)
CowboyCEO's Avatar
71roadrunner previously said: View Post
Here's a pic of the inside of an intact bell housing showing the quill surrounding the splined transmission input shaft. Top pic also shows the clutch release fork and TO bearing.
Here is a shot of mine from a similar angle with what's left of my T.O. bearing is resting on the input shaft.
That sucker got owned! Broke the sleeve clean off
Hopefully, the new Bell Housing wraps up the repair.
I miss 9-Ball
get well soon buddy
Old 11-30-2012, 11:05 PM   #54 (permalink)
Farmer Brown's Avatar
Member Number: 34579
Nasty.
I imagine there was a cacophony of metal the moment it happened.
I hope your truck gets fixed soon - holidays, and all.
If you have any vehicular problems that may result in potential safety issues in the long run that Toyota's simply putting a Band - Aid® on or ignoring outright (be it Premature Throwout Bearing Wear, Weak Fenders, Vibrating Steering Columns, etc.), make the issue known and report it to the NHTSA through the link below.
https://www-odi.nhtsa.dot.gov/Vehicl...nt/index.xhtml
Farmer Brown is offline
Old 11-30-2012, 11:27 PM   #55 (permalink)
CowboyCEO's Avatar
The sound not only sent chills down my bones. I also felt it in the pedal.. Like XX-BlackOut stated, "Pucker Factor 10".
If everything falls into place. I should be up and rolling mid week.
Old 12-01-2012, 07:08 AM   #56 (permalink)
jimmiee's Avatar
Member Number: 4830
lqdchkn previously said: View Post
Looks like the bell housing to me. I see TOB pieces, clutch fork, input shaft.
Yep, that's the inside of the bell housing. The throw out bearing sleeve or quill as some call it snapped right off. This happens as a result of the bearing failure. As you can see this quill is part of the bell housing. On many transmissions this part bolts on and is called the front bearing retainer. Many Toyota transmissions use a bolt on retainer but this one does not. It's cheaper to cast it as part of the bell housing. The bad news is you have to replace the whole bell housing if it breaks or is worn.
Im not sure if CowboyCEO said he had any warning before this happened? Usually you will feel the throw out bearing with your foot when it starts to go bad. You will also hear it when you step on the clutch. If you own a MT and feel the bearing get rough or start to make noise the best advice it to get the truck into the shop ASAP before the bearing explodes.
And lastly don't get the famous squeak confused with a bearing failure like this. The squeak is a whole different animal.
Forty Years of FJs
*1967 FJ40 Rock Crawler & 2007 FJ Voodoo Blue*
OME 3"Lift - Light Racing UCA - DeMello Bumper - 12,000# Winch - Warn Rear Bumper - MagnaFlow - Cobra CB / Bandi Mt - A-Track, Diff Lock, VSC, & Door Chime Hacks - 285-70-17 Bridgestones - 2 Horns / Wolo Bad Boy - Chrome Tube Front Grill - Ellis Shift Knobs & Batt clamp - Sylvania Silver Stars - Clazzio Leather - Blue Sea Fuse Panel - Die Hard Battery - Kenwood DNX6980 Nav Radio - Oznium LED Dome Lights - Prodigy Controller -SCUBA - Tinted Windows - Springtail Rear Door / Side Rack Combo - Tru Cool 4454 Cooler - VIAIR onboard Sys -All-Pro Sliders
https://www.facebook.com/jim.eberhart
TCLA Member 4407
jimmiee is offline
Old 12-01-2012, 09:50 AM   #57 (permalink)
CowboyCEO's Avatar
The sound was definately different than "the Chirp". I would say that I had less than a "two minute warning" before the ref tossed a flag.
My luck had me backing out of a parking spot when this all went down. The sound was a "za-ZA-ZA-ZING-Ga-CLUNK-ka-Clunk-Ka-CLunK!" Plus, that sound was translated thru the pedal.
For what this is costing me when compaired to the number and quality of miles I have driven. I am not going to say a single bad thing about how any of these parts were designed or how they failed. But I will always keep that "Mystery Bearing" as a reminder. "When then chirp turns into a za-Za-Za-Zing!" - Shut'r down and call a tow truck.
I am stoked to be driving a vehichle that has created such a broad and supportive familly. Keep the stoke alive and don't forget to wave at fellow FJ'ers!
Old 12-01-2012, 10:15 AM   #58 (permalink)
jimmiee's Avatar
Member Number: 4830
All of this could have been avoided you know; if you had just bought an FJ without a clutch pedal.
Forty Years of FJs
TCLA Member 4407
jimmiee is offline
Old 12-01-2012, 10:44 AM   #59 (permalink)
CowboyCEO's Avatar
jimmiee previously said: View Post
To tell you the gosh dern truth. The "Two" reasons I found my self behind the wheel of one of these nuggets were;
#1- it had a clutch
#2- My long anticipated test drive of the Hummer H-3 (m/t) left me with a feeling like I had pooped in my pants then ran a marathon in high humidity.
Old 12-01-2012, 11:00 AM   #60 (permalink)
Dave(man)'s Avatar
Member Number: 47156
CowboyCEO previously said: View Post
#1- it had a clutch
Toyota should use that in their advertisments
2007 TRDSE
ZORT
you don't have a soul you are a soul you have a body
Dave(man) is offline
