Old 02-12-2007, 10:41 AM   #101 (permalink)
tjreishus's Avatar
Member Number: 9529
Re: The "No Cut" A-TRAC + RR DIFF Hack.
For those of you who have done the mod, have you used it in a situation that you feel you would not have been able to maneuver through without the mod? I am interested in doing it, but don't know if it is worth it. I know it only takes a couple hours max, and hardly any expense, but I havn't navigated anything that the a-trac alone couldn't handle. With that said, I still want toyota to take care of the problem, it is a feature we should all have. I called Toyota and they said they were aware of it, but they're not doing anything about it at this time. I think that if enough people call and complain, the better chance we have to get it done right. Here is the number to call.
1-800-331-4331
Option 6
Stay on the line to be transfered to the next available representative.
For all of you who helped to make this mod work, YOU ARE AWESOME! You have invested a lot of time and effort just to help other people out with this.
tjreishus is offline
Old 02-12-2007, 11:49 AM   #102 (permalink)
Tankota's Avatar
Member Number: 3884
tjreishus previously said: View Post
It only comes into play on some of the much harder stuff.. 80% of people may never need it because they will not attempt or encounter something that will need that extra pull.
I have very good proof it works wonders though. I was able to climb a hill, with stock tires, that despite several attempts by two trail team drivers with aftermarket tires but without the modification could not.
David Hale
2007 Sun Fusion FJ Cruiser - Project T2
Full Icon suspension - 2.5" reservoir shocks front and rear, Icon UCA's, Icon rear links. 34" Goodyear MT/R's, Bandi Mount, Demello bumpers front and rear, Demello Front Skid plates, 4x150W roof mounted KC's and safari lights, ATRAC-Hack.
2007 Yamaha Grizzly 700fi 4x4
2007 Yaris S-Sedan (DD)
http://www.offroadingadventures.com
TTORA-Socal member #38 TTORA Forum
Trail Crew Member
Tankota is offline
Old 02-12-2007, 11:52 AM   #103 (permalink)
Corey's Avatar
Member Number: 2902
I still have not done this mod, either the underhood or in the cab.
I have read in a few threads where members are having the dash light up now after doing the hack awhile back.
Sounds like the ECU is not liking the mod?
Still holding out for Toyota to see what they are going to do.
Perhaps they will step up to the plate and give us a fix.
Corey is offline
Old 02-12-2007, 02:00 PM   #104 (permalink)
Tankota's Avatar
Member Number: 3884
Corey previously said: View Post
Huh.. that's odd..I havn't seen those posts.. I've had the hack the longest time wise, and so far nothing has happend to mine.. probably put about 6000-7000 miles on it since then.. I wonder if it's some weird milage based thing? Or if something else is going on like the wire coming lose??
David Hale
Trail Crew Member
Tankota is offline
Old 02-12-2007, 02:08 PM   #105 (permalink)
Corey's Avatar
Member Number: 2902
Here is one.
ATRAC And Locked rear diff - IH8MUD.com Forum
Corey is offline
Old 02-12-2007, 02:31 PM   #106 (permalink)
superstar555's Avatar
Member Number: 7161
The ECU can't tell the difference between hacked and un-hacked, so I really doubt that there would be a problem in that regard. The hack just provides a steady state signal to the ECU that tells it : "Hey Mr. ECU, the rear diff is not locked", which is the same signal the ECU gets in a non-hacked truck 99.999% of the time.
superstar555 is offline
Old 02-12-2007, 03:15 PM   #107 (permalink)
Razor J's Avatar
Member Number: 4495
Send a message via MSN to Razor J
I was in a muddy ravine, dropped my rear axle into a ditch and could not pull out with the rear locked and 1 front spinning in the mud. Another angled muddy ditch was in front and would require careful skirting, so a momentum assault was a poor option. This mod would have likely gotten me out on this situation-instead, it became a winching affair. I plan this hack but agree that it will be a rare occasion when I really need it
Razor J is offline
Old 02-12-2007, 06:52 PM   #108 (permalink)
tjreishus's Avatar
Member Number: 9529
Tankota previously said: View Post
Thanks Tankota, thats good info. I really, really want to do this mod, but I am so afraid that I am going end up damaging the ECU either by a mistake I make or from finding out later that this does damage to it. Maybe overly paranoid, so i'm not sure what to do. I know I want the mod, thats for sure.
Old 02-12-2007, 10:41 PM   #109 (permalink)
Tankota's Avatar
Member Number: 3884
Ok, fixed that one.. looks like it was a bad power splice.. Next!
David Hale
Trail Crew Member
Tankota is offline
Old 02-14-2007, 10:36 AM   #110 (permalink)
Member Number: 7161
FAQ UPDATE 2/14/2007
"I accidentally connected the +12v wire to the wrong side of the circuit. Now my truck will not start"
Correct the hack, and check the 10A IGN fuse in the drivers side fuse panel. If blown (it is), replace it.
