Old 01-05-2007, 01:08 AM   #81
FJammin's Avatar
Member Number: 878
Re: The "No Cut" A-TRAC + RR DIFF Hack.
Did it in no time flat, now that I'm bold with my mods. It worked right away, and I love it. Makes up a little for paying for Atrac when others didn't have to. Thanks so much for coming up with this.
'07 Ti, Up2, Rails, Half-Rack, Toytech 3" lift, BFG AT 285's, Infinity Reference speakers, Heated seat, remote starter, Atrac+locker hack. TRD CAI. Black A-pillars, Metaltech front bumper, Superwinch epi9000, white "cap" instead of just roof.
FJammin is offline
Old 01-14-2007, 09:37 PM   #82
Member Number: 8794
Great instructions,did mine, works great,you guys are awesome.Thanks alot.
wadecc04fj is offline
Old 01-17-2007, 05:19 PM   #83
DoubleTrouble's Avatar
Member Number: 8483
Send a message via Yahoo to DoubleTrouble
Re: The "No Cut" A-TRAC + RR DIFF Hack - UPDATED!.
superstar555 previously said: View Post
PROBLEM: Early production 2007 model FJs (~pre-November 2006) do not allow A-TRAC to operate in conjunction with the Rear Differential Locker (RR DIFF LOCK) or vice-versa. The ECU allows only one or the other to be active, but not both.
My question is in activating both Locker and A-TRAC. Today in Dallas we had a little snow/ice. I picked up my FJ on 12/30/06 so I don't know if its pre-November or not. I did the following.
1.)L4 then pressed Locker.
2.)Moved forward until indicator light quit flashing.
3.)Pressed A-TRAC - A-TRAC light came on.
From there I punched it to see how it felt. (very stable) then I turned off A-TRAC and punched it again. Didn't feel as stable especially in the steering wheel. (straight line)
So,,,, Does this mean I'm Post or Pre November????
DoubleTrouble (Katherine Steve)
DoubleTrouble is offline
Old 01-18-2007, 06:56 AM   #84
ruebarb's Avatar
Member Number: 1493
DoubleTrouble previously said: View Post
Since you don't get much snow in Texas, but, OVERKILL. Worst case you needed 4H to deal with the ice, likely you didn't even need that.
ruebarb is offline
Old 01-18-2007, 05:00 PM   #85
Member Number: 8483
ruebarb previously said: View Post
That wasn't the point here. Its was my only possibility at this time of the weather here to try to determine what features work and what features don't in regard to Pre November v.s. Post November on the A-TRAC issue. But I do appreciate your input.. I was looking more of a comment from someone who's experienced the functionality of the features/feel so I can determine whether or not I need the A-TRAC mod or not....
Old 01-22-2007, 03:56 PM   #86
superstar555's Avatar
Member Number: 7161
You don't need the mod.
superstar555 is offline
Old 01-29-2007, 11:55 PM   #87
geoff's Avatar
Member Number: 7410
The links on the first post are broken... any way they could be re-linked?
geoff is offline
Old 01-30-2007, 10:26 AM   #88
Member Number: 5289
geoff previously said: View Post
Please fix the post I was ready to do this today and now its gone. HELP
fishinfulltime is offline
Old 01-30-2007, 06:57 PM   #89
Ripsnort's Avatar
Member Number: 8953
I checked my build date--> 11/06.. then I fired her up and put the A-Track on, and locker on, then put it in different lock gear. Had A-trak light on, and both green and red rear diff lights on, so I assume I'm okay. (Shrugs)
Ripsnort's Stable
Lifetime Memories Productions-Sports Photography
TLCA #17429
“Me fail english? Thats unpossible.”
Ripsnort is offline
Old 01-31-2007, 10:14 AM   #90
Kansas Law Dog's Avatar
Member Number: 931
Ripsnort previously said: View Post
Please go out and play in some soft dirt or snow, and report back. You are the first to verify the lights work, but it would be nice to have verification that rear locker and ATRAC work together on a base vehicle (or CQ option) with rear locker after performing the switch install. Thanks in advance. If you accelerate to the point of slippage, the braking noise (from ATRAC) should only be heard on the front axles, as the rear wheels should turn at the same rpm all the time locker is engaged.
Kansas Law Dog is offline
