slalomkayaker previously said:
I think this mod could be alot easier if we find a way to trick the computer into thinking it is in 4LL.
No error codes, only a switch to be activated...hmm if someone with more electrical experience could help that would be great.
Thanks!!
I think I have found a way to put in a switch that will fool the skid ctl ecu into thinking the truck is in 4wd low. Unfortunately, I'm out of town until Sunday and can't test this so maybe one of you will give it a try.
In order to fool the ecu and not generate any error codes, I think both the EX1 and EXl4 will need to be grounded. This is how the thing works: when you put the truck into 4hi (HL)--EX1 is gounded; and when you shift into 4lo (LL)--EXl4 is grounded. See page 190 of the electrical diagrams.
One switch will ground both wires if a DPDT switch is used. I found a switch at RadioShack.com that would work:
RadioShack.com - Cables, Parts & Connectors: Component parts: Switches: DPDT Heavy-Duty Rocker Switch It's part number 275-691. See the drawing I made of the back of the switch with the terminals represented by the short lines inside the box.
Also looking at p190 of the wiring diagram, you can see that both the grey EX1 wire and the white/blue EXl4 wire go to the same connector called EA2. This connector is located on the left kick panel. See p51 of the wiring diagrams and the picture shows where the EA2 connector is located, although it's hard to see exact detail. You would have to look and find the connector and locate the two wires. Using this connector would allow easy switch wiring since the two wires are together. By disconnecting the skid control connector, you can use an Ohm meter or continuity tester to determine which end of the cut EX1 and EXl4 wires go to the ecu. These are the ends that need to be attached to the center terminals of the switch.
You would want to cut the two wires and connect a length of new wire to each end of each wire to run up to your switch. There would be four wires going to the switch. Looking at the left half of my drawing, you can see the four wires coming to and from the switch. Grey for EX1 and light blue for EXl4. Remember you're viewing the switch from the rear and looking at the six spades sticking out of the back of the switch.
The right half of the drawing shows the ground circuit that would be active when the switch is set to VSC/TRAC off. Power will be coming in from the skid control ecu to the center terminals and going to ground through the right side terminals. Splice the two ground wires together and attach to any grounded bolt under the dash. In this position, the skid control ecu will get the normal 4wd low signals and should turn on the "VSC OFF" light and the "squiggly skid symbol" light. Yippie, VSC and TRAC are off!!
When the switch is in the left position (in my drawing) the EX1 and EXl4 circuits would be connected just like they were before the mod and everything would be normal. VSC and TRAC are on.
Make sure you use a switch that has just two positions and not one that has an on-off-on or you'll set codes for an open in the circuits when in the center position. I'm just putting this out there if someone wants to give it a try.
Good luck,
Bugs
