Old 10-26-2007, 11:32 PM   #131 (permalink)
dbbd1's Avatar
Member Number: 1611
Re: Install of VSC cancel switch
bernd previously said: View Post
Thanks dbbd1 it works great. Gave it a good test on some gravel with it on and off. What a differance. I like the fact that you can turn it on or off at any time. No engine shut down to rest lights.
I really think that this is the only way to go.
alsharji previously said: View Post
Hi there,
I just did all the steps lited and my cancel (disabling the VSC is working) but once i try to switch it back on( enabling it) it wouldnt do so unless i turn of the engine and start it up again :S is that how it should or mine is just messed up ?
Thanks
With this mod, yes, you have to reset to error code you generated.
dbbd1 is offline
Old 11-15-2007, 09:49 PM   #132 (permalink)
sonof40's Avatar
Member Number: 11473
I've been reading this thread and its links for an hour now. Great job by all...
Can someone point me to a single post that performs the mod after all the kinks have been worked out? Don't mean to be lazy but I'm a little dizzy...
perciate it
Steve
TLCA 14294
KJ6DAA
sonof40 is offline
Old 11-15-2007, 10:10 PM   #133 (permalink)
mtrent3450's Avatar
Member Number: 10303
sonof40 previously said: View Post
perciate it
I just did mine before our Mojave rd trip and what a difference it made. There was alot of sand and without this mod I would have had to switch into 4wd and then listen to the Jeep guys for an hour harrassing me about using
4wd when they were in 2wd.
mtrent3450 is offline
Old 11-22-2007, 04:56 PM   #134 (permalink)
toytaco's Avatar
Member Number: 8667
perciate it
bump.............same here. confused..........
toytaco is offline
Old 11-22-2007, 05:19 PM   #135 (permalink)
SoCalOcFj's Avatar
Member Number: 11253
Send a message via AIM to SoCalOcFj
FJCamel previously said: View Post
Hi there,
Thanks
Thats the way it works. When you are done using it........flip the toggle switch back to disengage/cycle your key off then on, all the lights will now be off and its ready for next time.
"It is better to die on your feet than to live on your knees."
~Emiliano Zapata~
07 4x4 auto VooDoo - My Fj Supermotors Link -
SoCalOcFj is offline
Old 12-04-2007, 07:00 PM   #136 (permalink)
NWFJCC Moderator
bernd's Avatar
Member Number: 7688
if you cut the blue wire. there is no need to cycle the key. this method allows you to turn it off the back on without shutting the vehicle down. It works great.
Bernd
bernd is offline
Old 12-04-2007, 10:25 PM   #137 (permalink)
dbbd1's Avatar
Member Number: 1611
+1^ it really is the easier mod....
dbbd1 is offline
Old 12-05-2007, 09:26 AM   #138 (permalink)
sonof40's Avatar
Ospreyguy originally said on post one to cut the blue (think he called it purple) did something change in the 136 posts since then?
Steve
TLCA 14294
KJ6DAA
sonof40 is offline
Old 12-05-2007, 05:18 PM   #139 (permalink)
truckhigh's Avatar
Member Number: 9956
PLEASE EXPLAIN!!!
My real name is "KARLO" so do you get the name "truckhigh"
truckhigh is offline
Old 12-05-2007, 05:59 PM   #140 (permalink)
dbbd1's Avatar
Member Number: 1611
dbbd1 previously said: View Post
This mod works. Just tried it out in the snow (we finally got some here). When you turn it off, the ABS, VSC Off, Squiggles lights come on, turn the switch back on and they go out.
traction control disable?
He already did. Please see the above post then follow the link to the easier mod.
dbbd1 is offline
