Old 11-11-2008, 10:25 PM   #201
NWFJCC Moderator
bernd's Avatar
Member Number: 7688
Re: Install of VSC cancel switch
amm009uk previously said: View Post
I did post #148 and cant believe this is not part of the setup. For sand driving its mandatory unless u like getting bogged down!
One interesting thing, sometimes the VSC TRC light comes on and then you you have to cycle the power on/off to reset everything. Really doesn't matter 1 bit though.
I only had that happen once. I was testing the switch at different speeds. When I switched it at 60mph the VSC TRC light came on. So from that point on I only switch it at low speeds.
Glad my post helped out
Bernd
bernd is offline
Old 11-24-2008, 12:50 AM   #202
projekt4's Avatar
Member Number: 16605
bernd>>>u rock>>thanks for the help! installed the switch today and everything works as you said!!
projekt4 is offline
Old 12-13-2008, 02:39 PM   #203
Member Number: 23356
RocKrawler previously said: View Post
Tried the 84988-35050 2WD FJ traction switch, it doesnt work on the 4WD computer EVEN THOUGH THE WIRING IS ALREADY THERE! The plug is attached to the inside of the upper left block off just above the center console.
I just purchased this switch, but for the 4WD FJ (84988-35070) thinking it would disengage the traction control so I could, "have a little fun" and found out it doesn't do anything. Like stated above, the wiring is already there, it is a momentary contact switch. Does anyone know why this does not work, or what this switch is actually ment to do? I wasn't looking to cut wires and thought that this switch would be my answer.
Thanks
Glendale NY
2008 Titanium Metallic
4X4TONKA is offline
Old 12-13-2008, 03:03 PM   #204
NWFJCC Moderator
bernd's Avatar
Member Number: 7688
projekt4 previously said: View Post
Glad you like it
Bernd
bernd is offline
Old 12-13-2008, 03:31 PM   #205
amaintaylor's Avatar
Member Number: 6569
4X4TONKA previously said: View Post
Thanks
The wiring is not already there. Go to post #148 and do as Bernd stated. This was for the 4X4 and I don't know if it works for the 2wd. I think the harness you are referring to is the LSD for the 4X2. Also you will need to modify a momentary switch to be on and off for this method.
-Brian-
2007 SC TRD - AKA "The Black Lemon"
Every Warranty Voiding Option Available - SE Model with Custom Fender Bulging and X-Large Cracking
amaintaylor is offline
Old 12-14-2008, 08:13 PM   #206
amaintaylor previously said: View Post
Just tring to understand, my FJ is 4WD.
The wiring behind the blank is in both the 2WD and the 4WD?
Glendale NY
4X4TONKA is offline
Old 12-17-2008, 10:17 PM   #207
mrt
Member Number: 4922
-Does anyone have the part number for the VSC switch on the 09's?
-How is the VSC switch wired in the stock 09's?
-Is the computer different to accomodate this in the 09?
mrt is offline
Old 01-10-2009, 03:00 PM   #208
bercrapper's Avatar
Member Number: 16472
just installed the switch using the blue and yellow wire with gray stripes. I should of done this mod the day i bought my fj. Thanks for hooking us up with this sweet mod!!!
bercrapper is offline
Old 01-13-2009, 12:10 AM   #209
MikeKelso's Avatar
Member Number: 23053
Did mine tonight using the blue and yellow with grey stripes as well. Very easy to do. No problems at all.
Kelso
Fast, Reliable, Cheap
Fast & Reliable wont be Cheap
Cheap & Reliable wont be Fast
Fast & Cheap wont be Reliable
MikeKelso is offline
Old 01-13-2009, 05:21 PM   #210
NWFJCC Moderator
bernd's Avatar
Member Number: 7688
I'm glad you guy's like this method. It has worked well for me.
Bernd
bernd is offline
