Transmissions / Transfer Cases / Traction AidsThis area is for discussion, questions and problems with the FJ Cruiser's gear train, including topics on A-TRAC, VSC, locking diffs, gear ratios, manual vs. AT, etc.
I just did the Blue yellow wire mod and it did not work on mine. 4x4 Auto no locking diff. any info would be nice, i know i got the Right wire Checked and rechecked aginst Zoomed in pics. bummer tho
^^^^^^ This mod was discovered in lieu of the Atrack hack. So I'm juessing if you do not have a locking rear diff it will not work. Sorry for your pains I will edit my post
NP, i can still go into the purple wire at the 2 pin connector plug on front of the Brake master,, will try that tomorrow and update everyone. will just have to settle for having to cycle my key to reset the system.
I'll let you know
I'll let you know
This will not turn your ABS off. Thanks for your help. I edited my post.
Ok. I did the Mod where you interupt the Purple wire at the 2 wire connector at the front of the master brake sylinder and it works just have to cycle the Key on and off to reset it. this will work but would have rather done it the other way.
Location: Carson/great lakes where the navy takes me!!!
Re: Install of VSC cancel switch
seems like a good mod with my supercharger that i am getting.......lol or not
Jonathan
2008 Sandstorm/4x4/AT/Pkg. Option E/Roof Rack/tow package/All Weather Floor Mats & Rear cargo*Tint, Alpine IVA-W505, Alpine Nav, TRD CAI, Clifford alarm, ARB compressor, demello slidders, Pro Comp recovery gear, hella black magic, blue sea fuse box, air dam, FOX 3" Lift Fully Adj w/res, AP 2"stiffer rear springs, also AP A-Arms, 285-70-17 BFG A/T XD series hoss, demello front bumper!
Special Amphibious Reconnaissance Corpsmen
my scion had that trac button off ......makes me wonder if they put it on a 18k car why not on a fj? we had the extra button space, in the scion it was on the left side of the steering wheel and the fj has those buttons there as well as blanks, and to my knowledge if you buy the "ultimate fj" from Toyota it only comes with one of those spots filled and the other still with a blank...correct me if i am wrong
Jonathan
hmm now we have to tie taht into the mod
Jonathan
