Old 05-15-2009, 06:29 PM   #231 (permalink)
fj_najd's Avatar
Member Number: 15431
Re: Install of VSC cancel switch
when you cut the Blue / yellow wire
can the ECU still monitor the transmition temp so when it goes high it will show in the dash
because with the old way some of my friends lost there tranys ( all auto ) because it didn't show them that the tranmitionis over heating and they didn't know
That is the Question for me
Black 2008 FJ Fully loaded
*Mods
aFe Dry filter
Doug Thorley long Headers
TRD brake Kit
H4 Hi/Lo Xenon lights
sOoOn 3" Left + 1000W inverter
fj_najd is offline
Old 05-15-2009, 08:08 PM   #232 (permalink)
NWFJCC Moderator
bernd's Avatar
Member Number: 7688
fj_najd previously said: View Post
I have had zero issues with the blue/yellow wire switch. It has been installed in my rig for more then two years. Then again I do not run it hard in the heat and sand.
Thanks for the update about the other method.
Bernd
bernd is offline
Old 05-15-2009, 10:09 PM   #233 (permalink)
amaintaylor's Avatar
Member Number: 6569
Yes it does monitor the transmission temperature. I overheated my transmission two times while using the disable option. Running in 2 hi and having fun in the sand. I stopped for a minute and it went off each time.
-Brian-
2007 SC TRD - "The Black Lemon"
Every Warranty Voiding Option Available - SE Model with Custom Fender Bulging and X-Large Cracking
amaintaylor is offline
Old 05-16-2009, 01:13 AM   #234 (permalink)
fj_najd's Avatar
amaintaylor previously said: View Post
Great dear friend then it is a sure done MOD
it beat the 2009 Traction canceling method because I can turn of the ABS too and that's the worst enemy in lose sand especially when your going down hell
Thanx again man
*Mods
aFe Dry filter
TRD brake Kit
fj_najd is offline
Old 05-21-2009, 07:18 AM   #235 (permalink)
Member Number: 25222
NEW NEW NEW
in Dubai there is one man says he can do the same 2009 VSC off switch for the 2008 models all what you have to do is to buy the 2009 switch and take it to his garage.
and he will reprogram the ECU (I think - he said re programing only ) to the 2009 programing and it will work !
I was told by one of my friends who done it
I wonder if you could just replace the ECU with the 2009 model and add the '09 switch? My '08 has only 5k miles and I'd like to have the mod without cutting any wires if it's possible and doesn't cost much.
GaThumper is offline
Old 05-24-2009, 06:47 AM   #236 (permalink)
Member Number: 27758
voodoo crooser previously said: View Post
I don't see the point of this mod. When I want VSC off I just put it into 4hi.
I think it will be still usefull if you are having manual trans. and you wish to do some offroad while you are in 4H with open center diff. so turning VSC will let you drive more smoth without needding to shift 4HLock..what do you think?
sportman is offline
Old 06-06-2009, 05:43 PM   #237 (permalink)
MichEE's Avatar
Member Number: 7210
bernd previously said: View Post
This will only work if you have Toyotas Electric Locking rear diff.
This is how I switched my VSC.
First you need to cut back the electrical tape around the wire harness leading to the CPU
Once you have the protective tape pulled back locate the small blue wire with the yellow stripe and gray cross lines.
Cut this wire and add a long lead to each end. Run these wires through the fire wall with a grommet. Determine were you want your switch and attach the wires to the switch.
I used a cheep generic switch that I bought at an auto store. Do not ground the switch to illuminate the switch light. When I did this the rear locker light was half illuminated.
This switch will turn off the VSC and ABS at the same time ( lights that come on are ABS, VSC off, and Squiggly car). You are able to turn it back on at any time and do not have to cycle the engine.
If you do this mod you are responsible for your own actions. I am posting this only to let people know what I did. I am not responsible for your actions and what you do to your vehicle.
I would like to thank original poster of the pics that I stole to make my post.
Thanks bernd!! I can't believe I waited this long to do this!!
Couple comments.
1.) Make sure you disconnect the battery before doing this - you don't want to toast any electronics
2.) See attached pic. The connector comes off by pulling (toward the front of the vehicle) on the white tab.
What's your excuse??? Ti, 5AT, Hand Controls, hitch, 10sNE1?
MichEE is offline
Old 07-25-2009, 10:18 PM   #238 (permalink)
ohiobenz's Avatar
Member Number: 25920
Send a message via AIM to ohiobenz Send a message via Yahoo to ohiobenz Send a message via Skype™ to ohiobenz
where does this wire go to?
I would like to cut/splice it in a less conspicuous location!
i have an 08MT with the Atrac switch so this sounds like the ticket for me Thanks Bernd!!
'08 Fusion: ARB rack, custom ladder & Hi-lift mount, DO front bumper, Expedition-1 Rear bumper, DO Hybrid Sliders, MileMarker Hyd Winch, SPEC Stage-1 clutch, Icon Stage 2 3" lift, Cobra CB, & more......
'07 Hayabusa - for the fast trips...
http://www.fjcruiserforums.com/forums/image.php?type=sigpic&userid=25920&dateline=124699  3332
ohiobenz is offline
Old 07-31-2009, 12:51 PM   #239 (permalink)
Member Number: 29245
DO NOT DO THIS MOD!!
I spliced the wrong wire apparently. When I flipped the toggle to on, the roof flew off and the passenger seat went flying out into traffic behind me!
Wait, I am going to tell my ex wife we need to talk and to take a ride with me.
JK
GREAT MOD!
cparkerson is offline
Old 08-01-2009, 02:00 PM   #240 (permalink)
fj_najd's Avatar
Hi there again
I did the reading again for this subject, from zero ( post number 1 )
and I found out that we came very dam close to solve more than one problem but then we drift away again (I don't know why).
---------------------------- We start again -------------------
31moppie previously said: View Post
Tried a whole bunch of different things tonight and only came up with one improvement. At the RDL ECU, there is a violet wire with a red stripe. It is the last wire in that row. Just cut that wire and tape up both ends and you can engage the RDL at any speed. Be warned that it may not engage right away. The light may flash for a while until there is some differential action between the axles and the unit can engage. The wire that we cut is a speed control wire and does nothing else (that I'm aware of) LOL
Well, that's me done for awhile, off to Mexico for a week. Sure will miss all of this snow and -30 degree weather.... right!!!
[ there is a violet wire with a red stripe. It is the last wire in that row.]
-I think you just solved a big problem for many of us, we can trick the ECU and go over the speed which is limited by the ECU by a click of a switch.
My FJ goes until 180 KM\H now I can cut it and go more...
Finally got the fj back in my shop to try these wiring changes. Things looked promising to start. I connected the white/blue wire to ground and the traction control(squiggley lines) lit up. Connect the grey wire to ground and the VSC OFF light came on. Took truck for a drive with just the traction control disabled and I could spin the wheels and rev the engine (no power cut back) but there was some brake actuator activity. Then the check engine light came on and also the VSC Trac light and the VSC OFF light. Now you can do doughnuts! Tried the rear diff lock and it works too. ATRAC works too but is disabled as soon as the check engine light comes on. Had to disconnect the battery to clear codes and turn off lights.
Next, I tried both wires grounded out at the same time. This produced pretty much the same result. Running it again with only the grey wire grounded (VSC OFF light on only) I could spin the wheels, do doughnuts and there was no power cut back from engine. No check engine light this either but the rear diff lock doesn't work either which sucks.
Going to sleep on it and maybe something will come to mind.
[ I connected the white/blue wire to ground and the traction control(squiggley lines) lit up.]
-but !! you cannot run the RPM above 3000 ( if you are using an AT and shift into D.
[ Connect the grey wire to ground and the VSC OFF light came on. ]
-Good but you ended up with ?
[ Then the check engine light came on and also the VSC Trac light and the VSC OFF light. Now you can do doughnuts! Tried the rear diff lock and it works too. ATRAC works too but is disabled as soon as the check engine light comes on. ]
-and here is what why we cannot use it. . .
[ Had to disconnect the battery to clear codes and turn off lights. ]
[ I tried both wires grounded out at the same time. This produced pretty much the same result.]
-that is bad
[Running it again with only the grey wire grounded (VSC OFF light on only) I could spin the wheels, do doughnuts and there was no power cut back from engine. No check engine light this either]
-that is good but do you need to restart the engine to turn it off ?? I think so
[but the rear diff lock doesn't work either which sucks] . . . true
-thank you my friend
bugs1961 previously said: View Post
Hey, no problem! I started to read the thread you started but was overwhelmed by all the negative vibes, so to speak. I have used my VSC/TRAC cancel switch on several occasions where I knew the truck would get fooled by one tire momentarily slipping, like sand along the edge of the street (from all the snow we have been having--sanded roads). You have to pull out from businesses into 45mph traffic and there isn't usually a big opening so you pretty much have to be aggressive. The TRAC can be very unnerving trying to get into traffic and the FJ just won't go. Good luck with everything.
Bugs
-True but the bad thing is many people don't understand that it is a must to have a traction off switch and yes it for safety not only fun or off road ( if you say I am wrong then why the Lexus 460L have a traction off switch and the new FJ too I am sure it is not because of FUN factor )
TazmanianFJ previously said: View Post
I found the wire gray wire that the 4wd tells the Skid Control ECU to turn off VSC. I also found the white/blue stripe wire that turns off the slip indicator. These are the wires running into the Skid Control ECU. I took a pic of the two wires. Gray = VSC off, white/blue stripe = Slip indicator off. Grounding these wires takes the voltage away and in turn turns off the VSC or Slip indicator.
I also found that the gray wire runs to a connector just behind the glovebox if you would rather work with it inside the cab. The white/blue stripe wire is behind the gauge cluster. I couldn't get to that one.
I tried these and they did in fact work. When I removed the ground the system came back on without restarting the vehicle. I was going to add two switches, one for each wire. They would apply the ground when I turned on the switch.
I decided not to do this because when I turn on my locker from my locker mod, my VSC and my slip indicator turn off. That is what I wanted.
Hope this helps someone in their quest to customize. Do this at your own risk.
Nice work great SUM .
[ I also found that the gray wire runs to a connector just behind the glovebox if you would rather work with it inside the cab. The white/blue stripe wire is behind the gauge cluster. I couldn't get to that one.
I tried these and they did in fact work. When I removed the ground the system came back on without restarting the vehicle. I was going to add two switches, one for each wire. They would apply the ground when I turned on the switch.]
- My friend you are too dam close now. I need to know few things from you:
1- do you need to restart the engine to turn it off?
--No you dont
2- DO you have any lose of power or the transmission start to shift up in low RPM ?
3- Do you get the trany over heating light? I need to know if it can show that too. ( so we don't have to replace them )
4- do you get any bugs or problems?
- Can you add photo for the wires for conformation??
RocKrawler previously said: View Post
Has anybody tried running loose sand with this mod, and if so, did you notice a substantial improvement? While at TDS last weekend, the FJ struggled to make it up the sand hill behind the main camp - the more gas you gave it the seemingly slower it went. Tacomas can fly past me on sand hills, but the Fj just plain blows in loose sand. I like the idea of this mod if it will help in this situation.
EDIT: Thanks Bugs for the writeup, electrical is not my specialty, and plain english with pictures really helps guys like me.
YES, it helps a million dear friend I challenged a friend my 2008 FJ and his 2009 he turned both traction and VSC and I did not. there is a huge improvement.
*Mods
aFe Dry filter
TRD brake Kit
fj_najd is offline
