Old 06-25-2009, 05:34 PM   #1
Member Number: 25914
Diff Oil Spec Question... I DID SEARCH FOR THE ANSWER
My owners manual calls for 75-85 in the front and read diff.
BUT...
You guys are all using 75-90, is there a reason other than the fact that NO ONE OTHER THAN TOYOTA sells a 75-85?
Thanks
Sharky is offline
Old 06-25-2009, 05:55 PM   #2
Macleod's Avatar
Member Number: 11797
Re: Diff Oil Spec Question... I DID SEARCH FOR THE ANSWER
How about I throw another curveball at you. I just had work done on my front diff, manual transmission and transfer case, and Toyota refilled everything with 80W90 gear oil according to the invoice.
-Jen
07 Voodoo 6MT--Icon 3" suspension setup, Nitto Terra Grapplers (285/70/17), ARB Bull Bar, Safari Snorkel, Big Bill Combo w/ 3' Firestick, Wet Okole seat covers, Nuvi 660, M-PAC side rack, Rasta skids, '08 side visor mod, 3 additional 12V outlets installed, M. Schrader roofrack flag mount clamp, ScanGauge II, SCUBA mod, A-TRAC hacked, Springtail cargo barrier, Sonoran Steel rear lower links.
Macleod is offline
Old 06-25-2009, 06:08 PM   #3
DEWFPO's Avatar
Member Number: 7505
Sharky previously said: View Post
BUT...
Thanks
That's pretty much it, plus most folks go with a better quality (synthetic) oil.
DEWFPO
Engine Block Heater, '08 Cyclone Pre-Filter, Dual horns, Phillips Osram 70W/65W H4's, RockBlocker and 3M Clear Film, Toyota RearSight Backup Camera.
"Enjoying the Journey"
DEWFPO is offline
Old 06-25-2009, 06:10 PM   #4
1911's Avatar
Member Number: 4994
Nope.
N5MUD
TLCA # 16550
High Desert Cruisers
1911 is online now
Old 06-25-2009, 10:56 PM   #5
1911 previously said: View Post
Nope.
That's all I need to know.
There are rules to viscosity... Some must be adhered to strictly some can be fudged quite a bit.
For example; I know that the first # for engine oil is not set in stone while the second # needs to be watched closely.
A 0w50 will preform better in a car that calls for a 10w50.
While a motorcycle the needs 5w30 would take a hit in performance with a 0w50.
Didn't know if the same held true for diffs.
THanks for the replys!
Sharky is offline
Old 06-26-2009, 09:34 AM   #6
1911's Avatar
Member Number: 4994
I defy anyone (without an accurate viscometer) to tell the difference between 75w-85 and 75w-90 gear lube. I'd bet money that if you went to any Toyota dealer in North America and paid them to service your diff, they would re-fill it with cheap 75w-90 from a bulk tank.
N5MUD
TLCA # 16550
1911 is online now
Old 06-26-2009, 12:19 PM   #7
I wouldn't take that bet against you as I am confident you are right.
Sharky is offline
Old 06-26-2009, 10:48 PM   #8
rrjames's Avatar
Member Number: 15828
Gotta love the fact that Toyota tried to corner the market and failed. 75w90 is fine.
The dealerships get a little cranky when they cant overcharge you for oil.
08 Trail Teams 6MT
The Polar Bear
rrjames is offline
Old 06-27-2009, 10:56 AM   #9
Member Number: 14683
Yep, same as motor oil. They poo-poo whatever oil you'd bring in to use, but the no-name crap sitting in the tote bin out back is supposed to be wonderful stuff
Even if the tote bin is contaminated with rust, water, and dirt
jayman is offline
Old 06-30-2009, 11:22 AM   #10
Jond0's Avatar
Member Number: 24023
But they probably would still charge for the 'better than gold' toyota brand synthetic!
Jond0 is offline
