Transmissions / Transfer Cases / Traction AidsThis area is for discussion, questions and problems with the FJ Cruiser's gear train, including topics on A-TRAC, VSC, locking diffs, gear ratios, manual vs. AT, etc.
I started to shift my AT into N at the lights, thinking along the lines of both wear and fuel consumption, that is, more fuel being used while in gear, and then decided to do a bit of Googling to see what the consensus was. So far, in all my research, it seems to be 50-50 as to shift into N or not, but I came across an article in Car and Driver question and answers section where the same question was posed, to shift into N at the lights or not. Now, the answer was basically no, but their reason was one I hadn't heard of. They mentioned that after talking with a Toyota engineer, the newer vehicles actually shut off the fuel injectors when stopped, but in gear, to conserve fuel, and while the vehicle is in N, this feature is turned off, so they say keeping it in gear at the light saves more fuel. This sounds a bit strange to me, because my assumption would be if fuel injectors turned off, no gas, car stalls.....but I'm not a mechanic by any stretch of the imagination - so can't say 100% if this is correct or not.
If I can find confirmation from this Toyota engineer by way of an article that actually provides a name, I will post the article, but for now, I'm curious as to whether or not the FJ has this ability to conserve fuel by shutting off the injectors when stopped. And if this is true, when does this occur? As soon as one has stopped, or after a period of time, say, 30 seconds?
I may have to contact Toyota Canada directly to see if this is correct or not.....
Slàinte mhor a h-uile là a chi `s nach fhaic!
For so long as 100 men remain alive, we shall never under any conditions submit to the domination of the English. It is not for glory or riches or honours that we fight, but only for liberty, which no good man will consent to lose but with his life. - THE DECLARATION OF ARBROATH, 1320
Mods: Nuvi 350 GPS, XM Satellite Radio, Yaesu FTM-10R Mobile Ham, VE6RAO
I have never done this, but if it is proven to save some fuel AND help with wear and tear issues, then maybe.................
Sun Fusion 4X4 AT CQ GY DL FE XY PW CA TC QS
Mods to date: New and Improved Tire cover, with the FJ, tire tracks, and the word "Cruiser" free-hand painted by my wonderful wife
A-Trac,Dual horn,Goodyear Fortera Silent Armor's w/MB Razor wheels
Florida "Shark" specialty license plate saying "KRUSR"
Re: For those with AT's....
During my vacation in Spain last month, I rented a Mini Cooper diesel (MT). It has a feature that when shift to N and remove your foot off the clutch pedal, the engine stops immediately, but everything else stays on e.g. A/C, Radio..etc. However, you can turn this feature off.
When press the clutch pedal again, the engine starts automatically. As far as I know, starting the car and switching it off more often, consumes more gas, I dont know if this info is correct.
If this is true, I would think Toyota or somebody else would have mentioned it in their advertising as some sort of "green" feature.
Can someone explain how a fuel injected engine can idle for hours on end until the gas tank is empty when the injectors are "turned off" ? Is it pressure from the fuel pump or what ?
I call BS, at least as far as the current explanation.
2008 Sandstorm, AR Teflon Chamber, Nitto TG LT285/70/17, OME/Toytec lift, Total Chaos UCAs, BudBuilts, MPAC, Exp One w/Superwinch 9000s, BajaRack, Dual batteries, Viair 450A, ToyOutfitters LCAs
Visit the Woodsman here and hereand hereGot a Sandstorm ? Go here !
I'm the Woodsman, the four-wheelin', tree-farmin', custom-furniture-makin' descendant of Olaf "The Woodcutter" Ingjaldsson.
I used to drive a manual. The best part about driving stick is you don't have to put you foot on the brake ( or at least rarely do) when driving stick. Therefore, I have a natural tendency to put it into nuetral at lights. so yes. I do.
For years, some european manufacturers (Volvo's) have their engines set up to stop fuel delivery on deceleration above 2500 rpms. It's not noticeable to the driver and it saves some small amount of fuel.
Stopped in drive you are still heating up the ATF.
DEWFPO
So does this work the other way around ? If I used to have an automatic, should I drive a manual as though it were an auto ?
Seriously though, I used to and still do drive manuals depending on what vehicle I'm driving on any given day but I still remember how to drive each one correctly and safely.
One note on why you should keep it in gear for stopped or slow moving traffic . . . back in 2004 I was in very slow moving/stopped traffic on interstate 74 heading into Cincinnati in my Silverado. I caught a glimpse of a semi bearing down on me as though he did not see the traffic was stopped. I gave him as much time as possible (watching in my rearview mirror) and when it appeared that I was doomed I goosed it hard and launched the Silverado down the median. The semi skidded to a stop right where my truck had been sitting in the passing lane. The surrounding motorists looked towards me with amazement. I sh!t you not. True story. In fact, I was headed to a job interview and turned down a very good offer. I told the guy ( a good friend of mine) that, "I can't see myself living in the city to be close to the job and I certainly can't see wasting 2+ hours a day driving back and forth to work every day." Then he offered me a BMW as a company car. I still turned it down. Who the F wants to waste their life away sitting in traffic for hours a day ?
