Many of you have asked for them, and I've finally got the OEM fit dialed in, like I promised.
Here is the result:
All of the competing climate control knobs I've heard of get glued on with silicone... and that simply will not do if my name is on the box.
The Ellis Precision climate control knobs use the existing capture spring from your OEM plastic knobs, in a precisely machined custom-profile hole, to slide on securely to all three locations, just like the originals.
Install is as easy as sliding your plastic knobs off with a gentle pull, removing the capture spring with a small screwdriver or pick, inserting the spring into your custom anodized Ellis Precision climate knob, and sliding it back into position for use.
A lightly frosted precision lens will allow you to retain your OEM backlighting, with as much or more light transfer as the stock knobs.
A variety of finishes are offered, including matte black, matte red, black, red, clear, blue, and pewter.
If you have something else in mind, please ask!
Pricing:
Yes, these will be sold in sets of 3, of course!
$190 shipped in your choice of any plain anodized finish.
Matte finishes will be an additional $20 due to the additional time and resources required for the glass bead blasting process.
Dash dots on the sides will be $10 additional to cover the extra machining time and setup.
A pre-payment is required to confirm your order.
This group buy will close on August 1st. Orders are expected to ship by the 1st of September,.
To place an order, please PM me the following information in the following format:
Example:
Cheers,
Joel
Here is the result:
Pricing:
Example:
Thanks again for the support and enthusiasm I have received on this forum since 2006, when I had the original battery clamp idea. These products would not exist without this awesome community and forum, right here.
Cheers,
Joel
