Go Back   Toyota FJ Cruiser Forum > Buy/Sell Section > Want to Sell (FJ Related Items)
Want to Sell (FJ Related Items) List items that you desire to sell. More than one of the same item, or sale for continual profit entails the need to become an vendor. Please pm an admin to find out how.
Old 11-19-2009, 01:28 PM   #1 (permalink)
ALLOUTGEAR's Avatar
Member Number: 17390
RE SE D4 10" Sub Woofer
Oh man I really hate to do this and I have been saving this to use for myself and realized that times are just not right for me now. I must part with this, and you Audio people know this Sub is good stuff. I am asking $150 shipped for this beast, it weighs over 20lbs and shipping will not be cheap.
I do not and will not sell JUNK people.
Here is what is said about this beast, and specs.
RE Audio is known to make some of the best hard-hitting subs and amps. These are competition grade subs, which go super-loud. These are made with the best surrounds so they can withstand a lot of bass for long periods of time. With 600 true RMS watts, this sub is one of the most powerful 10" subs on the market. These are rated strictly. They do not have inflated peak ratings like some other lower brands do.
This is made to be a high excursion sub. This means it can hit a big range of frequency, and it can also pound a lot louder without over-heating.
Features:
* Impedance : Dual 4 ohm voice coils
* 600 watts true RMS Power! (No bootleg power ratings like cheaper brands, this is a huge 20 pound sub!)
* One-Way, Linear Excursion -Xmax: 18 mm
* Efficiency - SPL 1W/1m: 83.2 dB SPL
* Effective Piston Area -Sd: 310 cm^2
* DC Resistance -Re: 2.8 ohm
* Mounting Depth - 6"
* Mounting Hole Diameter - 9.25"
* Overall Diameter - 11"
* Bolt Hole Circle - 10.125"
* Motor Width - 6.25"
* Motor Depth - 3.25"
* Basket Depth - 2.75"
* Displacement - .14 cu. ft.
* Weight - 20 lbs.
* Dual Composite 2-piece Cone
* Rubatek Foam Surround
* Cast Aluminum Basket
* Tork-Tite Terminal
* 3" 4-layer Aluminum Voice Coil
* FEA Optimized Motor Structure
* Triple Stack Maganets
* Progressive Spiders
* Qes: .46
* Qms: 4.4
* Qts: .42
* Free Air Resonance -Fs: 26.6 Hz
* Vas: 31 liters
* Wrap around Rubber Gasket
If I had to Explain,you wouldn't understand.
[O]=TOYOTA=[O]
2008 Sandstorm FJC
1977 FJ40 - Locked and Loaded
1951 M100
2006 Lexus
2005 Harley
ALLOUTGEAR is offline
Old 11-19-2009, 04:04 PM   #2 (permalink)
MAXIMUMFJ's Avatar
Member Number: 30821
Re: RE SE D4 10" Sub Woofer
Does it come with the box and amp or just the sub
MAXIMUMFJ is offline
Old 11-19-2009, 04:09 PM   #3 (permalink)
ALLOUTGEAR's Avatar
MAXIMUMFJ previously said: View Post
Sub is in its original box.
If you mean a speaker box and Amp with the Sub for $150. NO and If you find that deal somewhere let me know and I am in.
[O]=TOYOTA=[O]
2008 Sandstorm FJC
1951 M100
2006 Lexus
2005 Harley
Old 11-20-2009, 08:41 AM   #4 (permalink)
ALLOUTGEAR's Avatar
TTT
Great Sub here people ....
[O]=TOYOTA=[O]
2008 Sandstorm FJC
1951 M100
2006 Lexus
2005 Harley
Old 11-21-2009, 05:12 PM   #5 (permalink)
ALLOUTGEAR's Avatar
Ttt..
[O]=TOYOTA=[O]
2008 Sandstorm FJC
1951 M100
2006 Lexus
2005 Harley
Old 11-26-2009, 11:08 AM   #6 (permalink)
ALLOUTGEAR's Avatar
Still up for grabs, put some bump in your ride.
[O]=TOYOTA=[O]
2008 Sandstorm FJC
1951 M100
2006 Lexus
2005 Harley
Old 11-30-2009, 12:25 PM   #7 (permalink)
ALLOUTGEAR's Avatar
New price = $140 Shipped Con U.S.
[O]=TOYOTA=[O]
2008 Sandstorm FJC
1951 M100
2006 Lexus
2005 Harley
Old 11-30-2009, 01:01 PM   #8 (permalink)
Kaster's Avatar
Member Number: 8821
Send a message via AIM to Kaster
How expensive would a nice amp be for this sub?
07 FJ Black 4x4
Kaster is offline
Old 11-30-2009, 01:31 PM   #9 (permalink)
ALLOUTGEAR's Avatar
Kaster previously said: View Post
Depends on what you want or what you are doing. Anywhere from $100 on up. You can find decent sub amps online for good deals, or just get a 4 channel that is Bridgeable and run your front speakers off two channels and bridge the other two to run the sub.
[O]=TOYOTA=[O]
2008 Sandstorm FJC
1951 M100
2006 Lexus
2005 Harley
Old 12-02-2009, 11:55 AM   #10 (permalink)
ALLOUTGEAR's Avatar
$130 Shipped ... I need this gone ...
[O]=TOYOTA=[O]
2008 Sandstorm FJC
1951 M100
2006 Lexus
2005 Harley
