Old 04-25-2006, 12:59 PM   #101
Member Number: 1311
Re: will 285/70-17 tires fit?
Dr Jeff previously said:
I have BFG AT's on my 2000 Dodge Dakota Quad Cab 4x4 Sport and they are great on wet roads and heavy rain. Way better than the Goodyear's that came with it. They were also excellent this winter in the snow. That is why I was considering them for my new FJ.
How bad is the mileage with the 285's compared to the stock tires. I am not expecting great mileage but I don't want to be stopping every 5 mintes to fill up either?
Have you seen the pictures from Fusion Cruiser on the other forum (the link is included in a previous response on this thread)? He says that he has no rubs at all with his tires on his stock FJ. I wonder what the difference is. Are his 33' GY Wrangler's smaller than the 285 BFG AT's?
Thanks for your input
I would guess mileage is down 20%-25%. With respect to wet handling, I have a somewhat distorted opinion because the car I replaced was astonishingly good in wet conditions. Most likely the tires will meet your expectations with respect to on-road wet and dry driving.
GTA_XAN is offline
Old 04-25-2006, 06:34 PM   #102
MoabRat's Avatar
Member Number: 1018
Send a message via MSN to MoabRat
Did you replace a WRX? My rex wagon was the best rain/snow car <edited for stupid typo> ever.
Pics of Our Adventures
BRC Moab Partner
TLCA# 16012
U4WDA
MoabRat is offline
Old 04-25-2006, 11:01 PM   #103
Member Number: 1835
Mileage is down? how much is the speedometer off? im sure the mileage loss isn't that large.. odometer off by 15% = actual mileage decrease of 5-10%
Bink Inc. is offline
Old 04-26-2006, 05:28 AM   #104
RalphWiggum's Avatar
Member Number: 1280
Exclamation Re: will 285/70-17 tires fit?
Uhhh... 15%??? He didn't put 37" tires on you noob! Learn to use your calculator (33 / 31.7 = 1.041; 4.1% increase) and don't make up numbers!
RalphWiggum is offline
Old 04-26-2006, 06:04 AM   #105
Member Number: 1311
The mileage drop is in small-part due to the increased tire size, more importantly, the weight is almost double the OE tire. It takes more effort to get the wheels rolling, couple that with the higher rolling resistance of the BFG, and ultimately mileage drops 15-20%. Please remember these are just my observations.
GTA_XAN is offline
Old 04-26-2006, 06:05 AM   #106
Member Number: 1311
993 C4S with S03's.
GTA_XAN is offline
Old 04-26-2006, 09:00 PM   #107
Member Number: 1535
unless they are bfg muds according to this guy's first hand:
http://forum.ih8mud.com/showthread.php?t=90563
but they look sweet. . .just a little hack needed or ome goodness. . .
m(a)ce is offline
Old 04-27-2006, 10:28 PM   #108
Member Number: 1835
Hey Ralph, you need to learn the difference between an example and a statement of fact. If you are going to try to act like you know what you are talking about, at least get your figures right.. rerun your numbers..
the actual difference would have have been even less.
If you are going to attempt to be the "guru" and clown me, shouldn't you have gotten the ACTUAL circumferences of the tires in question? how about tire pressures? ( those do in fact effect the actual circumferences, as does weight of vehicle ) how about frictionial losses?? road conditions? the list goes on and on..
Prior to calling me a "noob" you should have done your homework.
Oh yeah, just FYI... using your crude calculations you should of said 36" tires.. 37's would be closer to 18%
Grab your calculator and try again..
Old 04-28-2006, 04:05 PM   #109
MoabRat's Avatar
Member Number: 1018
Hi All,
One thing to consider as well. You just might be able to just clear 285s under the stock suspension setup but remember to leave some room for inexpensive articulation enhancements that are sure to come. The suspension is ok stock but is not very flexy (I think the rti was 481) There will surely be some inexpensive disconnects, better springs/shocks etc that will allow a more reasonable rti of 700-800 for offroading. That will surely start you wishing for a bit of extra space. Just for what it's worth.
BRC Moab Partner
TLCA# 16012
U4WDA
MoabRat is offline
Old 04-28-2006, 04:07 PM   #110
MoabRat's Avatar
Member Number: 1018
By the way I got the BFG ATko in 265s, thought someone might ask.
BRC Moab Partner
TLCA# 16012
U4WDA
MoabRat is offline
