Old 05-03-2006, 11:17 PM   #131
ropedrag's Avatar
Member Number: 2085
Re: will 285/70-17 tires fit?
will-285-70-17-tires-fit-one-leg-up-21.jpgYes!
ropedrag is offline
Old 05-04-2006, 12:26 AM   #132
Member Number: 1862
I just put on 285/70/17's today drove about 100 miles and so far no issues at all
JROD - Oakley Factory Pilot
Now
09 Aprilia Shiver 750
09 Harley Road Glide
09 KTM 530 EXC
08 Ducati S2R 1000
07 CLS63 AMG
07 S2000 Laguna Blue Supercharged 400HP
07 FJ Cruiser 4x4 VooDoo
05 TECHART Boxster S Atlas Grey
06 Magnum SRT8
Then
06 911 S Cab
06 Charger SRT8
05 Prius Silver
06 300 C "PIMP JUICE"
04 S2000 Mugenized
06 Ridgeline RTL R/S
05 Accord EX
04 Accord EX
03 G35 Coupe 6MT
03 Benz CLK
02 S2000
99 Boxster
56 Chevy Bel Air
FJrod is offline
Old 05-05-2006, 11:11 PM   #133
Member Number: 2106
Dr Jeff previously said:
I just ordered 275/70-17 BFG AT's for my FJ from Kal Tire. They should fit without rubbing at all and are a little bigger than the stock size. Why haven't more people looked into these as an option?
Got Muck???????????????????
Stuck'n Muck is offline
Old 05-06-2006, 08:17 PM   #134
jtratza's Avatar
Member Number: 1739
Topless4runner previously said:
good points corgi, and true. a good artice detailing the comparison between skiny and wide tires can be found here: http://www.expeditionswest.com/resea...tion_rev1.html
Great article on tire widths, preasure, traction etc. Thanks for the info.
Voodoo Blue 4X4
1987 Guards Red 911 Targa 250 hp in 2600 lbs
2003 BMW X5 (wife's)
jtratza is offline
Old 05-23-2006, 03:05 PM   #135
WLeRoy's Avatar
Member Number: 179
Folks, I just purchased my FJ. What is the best recommended lift? And what is the tallest tire that will run on the stock rims?
WLeRoy is offline
Old 05-27-2006, 07:38 AM   #136
SoonerFJ's Avatar
Member Number: 2501
Brian - VABeach previously said:
I'm also planning to upgrade to 285 BFG's if my FJ ever gets here. I'm wondering if you other guys that upgraded are seeing the same 15-20% loss in MPG that GTA is experiencing?
I realize these weigh 55 lbs vs 40 for stock tires, and I'm familiar with unsprung weight, but that decrease is way more than I expected.
TANX;
Brian
Brian, I have the 285 BFGs and we noticed about a 20% drop in our MPG. On the stock Dunlops we could get close to 300 miles on a tank with highway driving...now we get around 250 after the BFGs were installed. We filled up when the fuel light came on, so there was probably a 4-5 gallon reserve in the tank...giving us a drop from ROUGHLY 20mpg highway with the Dunlops, to 16-17 mpg highway with the BFG. This is after putting over 1100 miles of highway driving in the first week of ownership.
SoonerFJ is offline
Old 05-27-2006, 07:55 AM   #137
Member Number: 2229
I put on 285's. No rubbing at all.
wyomingtroutman is offline
Old 05-27-2006, 08:58 AM   #138
MoabRat's Avatar
Member Number: 1018
Send a message via MSN to MoabRat
Out of curiosity have you loaded them up with mud, or had full articulation at near wheel lock? With only a half inch of clearance at it's tightest spot I'm pretty curious how this'll workout in severe conditions. I seem to attract those.
Pics of Our Adventures
BRC Moab Partner
TLCA# 16012
U4WDA
MoabRat is offline
Old 05-31-2006, 12:15 AM   #139
fjarch's Avatar
Member Number: 1809
Ok... I know this thread is OOOOOLD news... but I need help... based on what Ive read here, 285's without lift will fit with no rubbing if no serious off-roading is involved. There is a 20% drop in MPG for these bigger tires because of (among others) the larger diameter and heavy weight of at least 15 lbs more (each) than the stock tires. I've always liked the looks of bigger tires. Should I sacrifice the looks for better MPG or the other way around? Should I go for the 265/70/17 BFG's or compromise with the Goodyear Wrangler AT Silent Armor 275/70/17's? I know Im the only person who can answer this but if one of you tells me that if I use the BFG 285's it's going to give me good luck, happiness and prosperity, and someday will marry a supermodel, I might believe you and go for it!
fjarch is offline
Old 05-31-2006, 12:32 AM   #140
SoonerFJ's Avatar
Member Number: 2501
Arch, Since upgrading to the 285 BFGs, we have been happy with them. They are MUCH better looking than the Dunlops and the road noise isn't all that different from stock. There is a small amount of rubbing, (more on the driver's side than the passenger) but we don't plan on doing any "serious" off-roading that would cause problems. If it is too much of a problem, I will get a 2" lift or go to the 265 BFGs. As for the gas milage...we just dropped over 30k on a vehicle that gets around 20 mpg on a good day. Fuel economy wasn't on the top of our list for features, but the thing sure looks good sitting on the new BFGs.
SoonerFJ is offline
