Old 06-06-2006, 12:26 PM   #151
Joey185's Avatar
Member Number: 1719
Re: will 285/70-17 tires fit?
SoonerFJ, You said 250 miles now but going to a larger diameter means your odometer is showing less miles than you really went. Figure about 10 miles for every hundred so you are probably getting about 275 out of it. Weight does effect it somewhat, but a larger diameter on the highway will actually give you better millage so it depends on what your driving habbits are.
Nobady that I've seen has tried the BFG Mud Terrian. When compared to the A/T in the same size they are slightly thiner. Any tire shop will tell you this. Just the way they are, but it is noticable. Switched from a/t to m/t on my superduty F-350 and then switched back because I didn't like the thin look it had. In a 285 a M/T is not going to be very loud at all. Has anyone checked to see if TOYO M/t are in 285/70/17's?
Elements used to be what I dreamed about, Now all I see is FJ's...
Joey185 is offline
Old 06-06-2006, 11:49 PM   #152
TANKyoueasterbunnybakbak's Avatar
Member Number: 2281
I put BFG AT/KO 285/70/17 with no lift and experienced significant rubbing, and so I switched to 265's. They look great and no rubbing!! It really depends on who you talk to regarding the possibility of rubbing, so you might luck out. Rubbing occurred mostly behind both front tire/wheels...
TANKyoueasterbunnybakbak is offline
Old 06-07-2006, 10:10 AM   #153
FJ #8's Avatar
Member Number: 121
Is anyone running 285/75/17 with a 3" lift?
FJ #8 is online now
Old 06-07-2006, 10:27 AM   #154
granger's Avatar
Member Number: 50
I'm running 275/70R17 MTRs with no rubbing. I have put it up on curbs at full turn and I'm still not close to rubbing. I'll have to see what happens when I get it off road though.
TLCA#15587
granger is offline
Old 06-07-2006, 10:37 AM   #155
OffRoad Rage's Avatar
Member Number: 1235
Just put on the Daystar 2.5" lift this weekend and new Nitto 285/70-17 Terra Grapplers. Just came out, they aren't even on the Nitto website yet but the Discount Tires here in the Phoenix area have them. Sweet.
"I AM my own worst enemy."
Daystar 2.5", 315/70-17 MT MTX's, Stock Steelies, BMC, LCA Sliders- Simple but effective.
OffRoad Rage is offline
Old 06-07-2006, 11:22 AM   #156
Joey185's Avatar
Member Number: 1719
With the 2.5 daystar, Do you lift the back as well? Nobody has said anything about the back. Just seems like if you lift the front only then it will ride high in front.
Joey185 is offline
Old 06-07-2006, 11:23 AM   #157
Joey185's Avatar
Member Number: 1719
missme's black FJ is the best setup I think, But I'm not sure what it is. He or She does not allow messages.
Joey185 is offline
Old 06-07-2006, 11:41 AM   #158
bandi's Avatar
Member Number: 2261
Thumbs up Re: will 285/70-17 tires fit?
shana previously said:
these are Cooper Discoverer STT 285/70/17.
These are Awsome looking tires Shana !!! Congrats on the Setup !! Enjoy your RIDE !!
[[[[[[[[[ DEMELLO FlatTop Bumpers ]]]]]]]]]
The "Bandi Mount" From ALL-PRO OFF-ROAD
bandi is offline
Old 06-07-2006, 01:30 PM   #159
aubuc1's Avatar
Member Number: 991
Send a message via MSN to aubuc1
I am ordering 285/70/17 mickey thompson atz's. I hope I am not making a mistake.
aubuc1 is offline
Old 06-07-2006, 02:45 PM   #160
Member Number: 1057
nice. Can you post some pics once you install them?
Broom is offline
