Re: will 285/70-17 tires fit?
I may do rubber before a lift and attempt the 285's. It's only an inch of difference and I'm not really into taking trails hard enough to require stretching the flex of my truck to the limits. Stock, it really has quite a bit of flex.
Not even flexed out. I can't see an inch in real diameter rubbing even running up a 2.5' mound of dirt like this one with the wheels turned.
It looks like, with the plastic fender flares on the FJ - you guys should have even more space to play with. Try it out and see. You never know if you don't try.
2006 Tacoma Access Cab 4.0ltr V6 TRD Offroad, 6 Speed Manly-man-mandingoness
"Too close for missiles, switching to guns."
Member #13 - no matter what that thing says.
